Question about Braun Syncro 7526 Electric Shaver
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
I have the same problem with my 7570 Braun shaver. The blue button came off but the shaver still works, How do I fix it. See the Jan. 2008 inquiry
  • 10 Answers
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 29, 2009
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
  • obau Dec 08, 2010
    thanks!
    brilliant solution for model 7765
    Novelist:
  • 124 Answers
You can obtain a replacement charging/cleaning base for only $18.99 at Shaver Outlet, as of this writing. Follow the link here: Shaver Outlet Parts. If the shaver is still working fine, it's worth getting the replacement base. Less than $25 shipped is a nice alternative to messing with velcro strips and rubber bands. :-)
Posted on May 23, 2009
  • Gary
    Gary May 23, 2009
    Ah, sorry... I can't delete my solution. I noticed that you're not talking about the button on the cleaner, but on the shaver. Sorry! :-/
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
Where can I buy foil for Braum shaver 7570
braun 7570 replacement foil and cutter blades is braun series 3 combi 30B screen foil and cutter replacement pack.
Dec 23, 2012 | Braun Syncro 7570 Electric Shaver
In the window section it reads "OIL"
The oil it refers to is applied to the screen and blades. You will find this type of oil at shaveroutlet.com
http://shaveroutlet.com/shaver-accessories/braun-shaver-oil-p-465.html
Nov 16, 2010 | Braun Syncro 7570 Electric Shaver
I have a braun 7570. The charge & clean is not working. I haven't used it for over a year. How would I clean it?
The bst way to clean it is to remove the foil and brush off the cutter with the brush that came with your shaver. You can also simply rinse the head under water as indicated in the user manual
If you would like to replace your clean and charge machine, you will find this item for sale at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html
Jun 11, 2010 | Braun Syncro 7570 Electric Shaver
Braun 7570 shaver wont charge but wont run on mains lead
My Pulsonic Razor that I received for Christmas will not run on battery, or with the plug supplied. I have tried just about everything I can think of. Is there a way to solve this problem? I do not have a receipt as it was a gift and am quite certain it would cost me a small fortune in order to fix it at a Braun Service centre.
Please help me if you can. TY
jbabcock12@cogeco.ca
Mar 14, 2010 | Braun 7000 Series Foil and Cutterblock
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
Feb 08, 2010 | Braun Syncro 7570 Electric Shaver
Looking for a service manual for the Braun 7570 syncro razer
It's actually easier than it looks. On the bottom of the shaver is the charging port. That black plastic piece surrounding it can be pried off. Do it carefully, so you don't dent/scratch the casing. Once removed, the side pieces easily remove. You'll now see screws holding the body together. Have at it. :-)
Jan 08, 2010 | Braun Syncro 7570 Electric Shaver
I need an instruction manual for the Speed xl 8175XL Phillips Norelco razor....any ideas?
http://www.amazon.com/Braun-Syncro-Shaver-Storage-7570/dp/B000050FDR
at the product details section of the page you will find the manual.
Dec 31, 2008 | Braun Syncro 7570 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
982 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
