Question about Philips Televison & Video
My tv antena is broken and i ma trying to assembe the cable to the thing that goes into tv. Any instraction please? The tvcable is not conected to the conector which goes into tv. I peeled the placstic part to take out a smal length of the middle metal
    Top Expert:
  • Philips Master
  • 75,304 Answers
Hello
If your TVs internal telescopic antenna has broken, you can us an external antenna from connecting to the rear antenna socket. For that you have to buy some extend of antenna cable, and a yagi antenna; as it is better for reception. If your TV screen size is 14" or below, a small wire of length 2 mteres or so is enough. Buy one Balun coil assembly fro electronic sparepart shop, and connect this wire to it, connect it to the antenna socket at the back of the TV, and with picutre just wave it to some side where you get the maximum picutre clarity.
If you TV screen size is more than 14 inches, external yagi antenna shoud be used for claear transmission reception, and it must be directed well towards the tranmitter also. Alaingning it is a trial and error process, at which position you gets the clearest picture, without any Ghosts. OK.
Posted on Dec 30, 2010
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
How do i make my vizio vx37l recive high definition antena signal
Go into menu and find TV input area--- change from cable to antenna
Mar 03, 2015 | Vizio Televison & Video
I have a flat tv olevia 332 b-11 my problem is that that I have no idea where the antena goes and the screen is blue and I don't know how to program the local chanels because is no hole in the tv
Ifyou look at the rear of the TV, you will see a round thing with threads on it. That's the antenna connector. You will probably see ANT or ANT INN marked nearby.
Dec 21, 2012 | Televison & Video
Trying to install channels on goodmans ld1962d. Not sure what active antenna is. No channels are found when we have aerial in or out.
check for antena cable plug condition, normaly 80% of low quality of antena signal, is conection on antena plug (inside)
1st open antena plug, check for condition/connection of cable.
2nd check for each part of cable well connected, and no wires crossed on middle cable
3rd check same to the other end of cable.
4rd check the signal on diferent tvs around house (if available)
if this general you dont have aerial signal in your house, check for your TV provider (cable) to test your arial signal.(Normaly this maybe a cable broken outside house).
Nov 22, 2009 | Televison & Video
Cut antenna wire raymarine 300waas gps
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
Oct 27, 2009 | Raymarine Raynav 300 GPS Receiver
I have analog tv, combo dvd vcr and magnavox converter how can i conect them
Put ur tv in channel 3.Take the colax cable came with the converter box put it in the hole in the converter box said tv in the hole cocnverter box,the other end of the colax cable put it in the tv set hole said antena.Now take ur anatena signal an indoor or roof antena put it in the converter box hole said antena in the converter box.Turn on ur converter box power on go to menu use scan channels,u should ready to go, when the scan channels is finish.
Oct 21, 2009 | Televison & Video
Broken connector to cable/antena
the only other way is if your TV have audio & video inputs , to purchase a RF MODULATOR by RADIO SHACK cat. no. 15-1244 , hope this helps , AJ
Jul 08, 2009 | Insignia Digital-to-Analog Converter for...
Connection to Tv-monitor from a VCR
Yes. You need a
scart to VGA cable
or a
Scart to HDMI Cable.
The second one is more expensive but has a better quality picture. Your tv should have these two ports. The 'scart' goes into the back of the video and the VGA / HDMI goes into the TV. They can be purchased at any of the sites i have listed below.
www.maplin.co.uk/searchtemplate.asp?criteria=SCART%20TO%20VGA%20CONVERTER -
www.tvcables.co.uk/cgi-bin/tvcables/scartleads.html -
www.cablesandleads.com/ -
Hope this help's you,
Hughie.
Jun 17, 2009 | Televison & Video
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
Televison & Video Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
