Question about Elna Quilter's Dream 6003Q
Bobbin winding won't clear off screen
I have an Elna 6003 and was winding bobbins. However, now the 'bobbin winding' description will not clear off the screen and display stitch width and length. The machine will sew, but I can't tell what stitch etc I am using. Any suggestions other than taking it in for service?
  • Anonymous Apr 18, 2009
    Machine ran fine. Stopped and wound bobbin and now the bobbin winding message will not clear. The machine runs but you have no control over the machine.
Am taking it to the shop.
Posted on Jul 08, 2008
My elna 7000 sewing machine does not want to wind the cotton
Not sure of the particular bobbin winding problem you are experiencing. However, frequently the bobbin winder "tire" becomes worn and needs to be replaced.
Elna 7000 Parts
What is the correct way to wind and insert bobbin in elna machine
Jul 20, 2016 | Elna Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
How to load bobbin with elna quilters dream 6003
here is a link for parts and a manual,, the information should be in it for the loading of the bobbin
http://www.sewingpartsonline.com/elna-6003-sewing-machine-parts.aspx
Mar 06, 2015 | Elna Sewing Machines
How to wind a bobbin on a 2004 elna sewing machine?
1 - Look in your book.
2 - Ask a sewer to show you.
3 - Google
Jul 16, 2014 | Elna Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
What is the correct way to wind and insert bobbin in elna machine?
You always wind the Elna 7 hole bobbin with the holes on top, and load it into the bobbin case the same way, this means when you draw the bottom thread off the bobbin, it will turn anticlockwise.
Apr 30, 2014 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I have the Elna 6003 quilter's dream machine. The problem is that it is stuck in the "bobbin winding" mode and will not allow me to change stitches. I have tried turning it off and turning it...
Does this have a bobbin winder post and stop at the top right. If so, is the bobbin winding post moved back to normal position or up against the post?
Being computerised, if you have tried powering it down and all the settings are correct, then it might want a trip in the car to see the technician to sort out this fault.
Apr 06, 2011 | Elna Quilter's Dream 6003Q
I need an elna bobbin case for the 6003 machine how much do these cost to send to london thanks geoandcurr@btinternet.com
Your Elna 6003 was made by Janome and has the same bobbin case as a Janome 4800. There are many Janome sewing machine dealers in London, one surely will stock the part.
Jan 16, 2010 | Sewing Machines
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
337 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
