Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
The gasket coming out of bottom of our sink erator was leaking and spewing. when we replace the washer before bolting on the gasket do we use plumbers putty?
Plumbers putty is for setting sink basket into sink.
I use rectoseal on all tubular washers and joints,
Smear it on thick and then assemble parts, and rectoseal ensures nothing will leak.
Posted on Dec 30, 2010
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 insink erator is leaking out of bottom. Is this a seal or something that can be replaced?
If it is actually leaking from the bottom there is nothing you can do except replace it, there are no user servicable parts in the bottom end on disposal. I would carefully check around drain outlet and gasket where it mounts on bottom of sink. If it's leaking around drain outlet from disposal there is a replaceable gasket there or on underside of sink where disposal mounts. If you find that it is leaking from either of these locations I would be happy to instruct you on how to change them Hope this helps you, Thanks.
Nov 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leakingfrombottom
Are you sure that it is leaking from the bottom and not around drain connection or mounting flange at bottom of sink. If it leaking around drain line you can try tightening hex head bolt that hold drain line to disposal. Also if that is where it's leaking and you cant stop it you can get a replacement gasket from hardware store. If it's leaking around mounting flange you can try tightening three slot headed bolts and see if that helps. There is also a gasket that fits between tiangular shaped mounting flange and bottom of sink that is replaceable. If it is actually leaking from the bottom of disposal then you will need to replace the disposal. hope this helps. Thanks
Nov 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water drippinp from the bottom of badger 5
Check all of your seals. Wipe your hand all the way around your disposal to check for moisture running down. Pay close attention to the areas where there are seals, like the top where the main gasket is located and the side where your drain connects there are rubber gaskets that can begin to leak. Also check where the dishwasher drain connects if applicable. If all gasketed areas are ruled out than unit itself may be leaking and need to be replaced. I hope this helps.
May 26, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
May 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dismantle Emerson insink erator
There is a retainer ring that holds the drain and the Insinkerator together. You loosened the drain with the 4 screws. You need to rotate the retainer ring counterclockwise when looking up from the bottom. Maybe 45 degrees and it will come loose. BE CAREFUL IT WILL WANT TO FALL!!
Phil
Dec 03, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
128 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
