Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off the "clean" light. For me to get it to run, I have to unplug it, plug it back in, push the start button until the ?washing? light comes on. I then push the start button once more and the dishwasher will begin to drain. I open the door as soon as I hear the water stop draining into the sink drain. This stops the cycle. When I am ready to wash again, I will fill up the dispenser with dishwashing detergent, shut the door and push the start button until Ii can get it to light up that it is "washing" and my dishwasher will work until the "clean" light comes on, the cycle stops, and the bottom of the dishwasher is full of water again. Any suggestions.
  • 1,531 Answers
By the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Posted on Dec 29, 2010
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: I need to replace my
The dispenser is usually mounted by a series of screws from the INSIDE of the door panel. You need to turn the breaker off to the dishwasher, open the door, and remove the inside door panel to access the dispenser. There also should be a couple of electric connectors going to the dispenser motor. Use care not to pull the wires when removing the panel. HINT: If your dishwasher is like most dishwashers, the door will try to close on you from the tension of the door springs. You can disconnect the door springs, which may require unmounting the dishwasher from its under-counter position, or you can make this process easier, by finding something to prop the door open with. I usually use a thick dowel rod, or cut off broom handle to prop the door open against the cabinet. I hope this helps you. If you need further assistance, please let me know.
PS For future reference, please post your complete model number when submitting questions about your applainces. This makes the process of assisting you much easier as all makes and models are NOT made the same.
Posted on Aug 20, 2008
bbtoast
  • 319 Answers
SOURCE: Detergent accidentally put into rinse dispenser
You need to use something to siphon the detergent out of the dispenser. I have plastic syringes for this type of purpose. You don't use the needle attachment.
If you cannot fit the syringe into the opening, then you may try to use clear plastic tubing to syphon out the detergent.
Once the flow of detergent stops, you should then use warm water to rinse the residue. If you have the syringe, you could use it to force water into the dispenser.
This may take a little time, but it is better than trying to disassemble stuff!
Good Luck
Brian
Posted on Jan 10, 2008
  • 8 Answers
SOURCE: Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Posted on Nov 21, 2008
  • 457 Answers
SOURCE: dishwaher detergent dispenser is not opening
go to searspartsdirect.com and put the model # in they will ship the part to you.
Posted on Mar 03, 2010
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Frigidaire Gallery Series Dishwasher - unit stops near the final rinse cycle without draining - "ER" on front display, all led indicators on front display also lit (e.g. low rinse agent, etc.),...
the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes.
it can also be the new electronic module.
If the electronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Apr 03, 2008 | Dishwashers
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Dishwasher
I have seen this problem before on a couple of dishwashers.
How are the dishes doing? Are they coming out clean, or do some of them "fail".
If you rinse the dishes before putting them in the dishwasher, it may be hard to detect "failure" to clean. Try not rinsing the dishes once and run them through a cycle. My guess is that the "failure" rate will be high.
The problem I have seen is that the dishwasher water input filter is either clogged or the water-full sensor is "telling" the unit that there is enough water in before it actually fills properly.
So, some water can get in, but not enough to properly wash the dishes and dissolve the soap.
On the appliance repair sites they have parts breakdown details and what you are looking for is an input valve assembly -- the point just after the water line connects to the dishwasher.
Now the valve may be OK, but the feedback system could be bad.
(On a Bosch dishwasher the valve IS the feedback system and the filter.)
Any filtering or "water full" signal will feed back to that valve.
If you get inside that front lower panel, be sure to turn the electricity off first 'cause if you get crosswise in that area you could end up with a 'shocking' experience!
good luck
May 09, 2009 | Dishwashers
Cloths still soking wet after rinse cycle
remove the front panel on the bottom look for a screw out filter bout 2 inches long youll see it screw it out clean the filter and reinstall the filter then the water should flow out on spin good luck
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
533 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
