Question about Airtronics Toys
How to pull output shaft gear from Airtronics 94581 sail winch servo
2 Suggested Answers
phillipstech
SOURCE: can not pull winch cable out had to take cover off
The clutch knob on the side needs to be loosened up. Rotate this and the shaft will be free to pull the cable out.
Posted on Dec 27, 2009
Transmission problem with a 2007 Mazda cx7
This indicates a problem in the transmission control module as it is not activating the solenoids/servos and consequently the sensors that read turbine speed and output shaft speed are not reading the correct difference of the two units . Have this checked out at an accredited auto transmission shop.
Jun 16, 2014 | Mazda CX7 Cars & Trucks
Hercules winch on timberjack 230 won't pull or hold a heavy load
check for failed sheer pin in the drive shaft attached to the winch brake.
Mar 02, 2014 | Cars & Trucks
2006 snow bear plow, winch will not lift plow, sounds like its turning but is not lifting plow consistantly, Is something loose?
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Jan 20, 2011 | 82" TruckSUV Snow Plow
What is the most important sailboat hardware?
If you are looking to sail with comfort, safety or performance you may have to put together not only the wind, the ocean, the sails but your sailboat hardware.From blocks for proper sail trim to furling units for easy sail handling. These are examples of some important salling hardware: Bailers, Blocks, Rigging, Winches, Shackles and rope cluches.
Aug 12, 2010 | Cannon Boating
I just bought a used mx-3x radio and i need info on how to set up or change setting i didn't get a manual with it, where can i find info on line
Sorry we do not have manual but you can get from info below.
– If you need more information, use these Airtronics resources – E-mail: info@airtronics.net Web Site: http://www.airtronics.net/ Phone: 714-963-0329 Postal Address: Airtronics GLOBAL HOBBY DIST. 18480 BANDILIER CIRCLE FOUNTAIN VALLEY, CA 92708
Good Luck and please rate 4 thumbs for free answer
Mar 02, 2010 | Airtronics Toys
Can not pull winch cable out had to take cover off
Nov 10, 2009 | Master Lock 5400d: Portable Select Access...
The problem i have is that the revers on my 1993 plymount voyager
it could be a bad low reverse servo, bad friction materials. if the friction materials are bad in the transmission then the "sun gear" will not be engaged. This is the gear that allows the planetary gearset to move the output shaft in reverse. So you are looking at a servo problem or a transmission rebuild.
Jun 12, 2009 | 1993 Plymouth Voyager
Linear servo retainer replacement for e-flite mcx
It isn't a great solution, but i was able to get one of these retainers back on. Using only the screwdriver in the kit, and my thumbnail. Try to work in a well-lit, clean area, so if the retainer gets loose, you can find it. Should be obvious, but Make sure the power is disconnected to the heli
--Heli Dis-assembly--
First, disconnect the two servo pushrods from the swashplate. Unless you want to replace the swashplate, be careful not to break the connecting ball off.
Second, disconnect the two motors from the control unit. Be mindful of the direction they need to be reconnected (white/black on outside, blue/orange on inside--in that order)
Third, using the provided screwdriver, remove the two screws holding the control unit on the heli. pull it off the chassis, but be mindful of the Antenna wire. I would try not to bend this more than you have to.
-Retainer installation-
Fourth, lay the control unit on the clean flat surface, pull the servo gear shaft slightly out of the unit until it is flush with the plastic.
Fifth, Carefully drop the retainer next to the servo. Using the tip of the screwdriver, apply enough pressure to the retainer to guide it up the plastic to match the hole with the shaft.
Sixth, Apply gentle but firm pressure upwards on the gear shaft. this should push the retainer onto the shaft just enough for it to hold on.
Seventh, using your thumbnail on one hand, and the tip of the screwdriver with the other, apply pressure to both sides of the retainer to slide it down the shaft. *NOTE* This is where i had the retainer flip off the gear shaft multiple times, only to have to repeat steps 4-7.
Eighth, Begin re-assembly in reverse order from steps 1-5. Reattach the canopy, and power, and attempt flight. If it spins uncontrollably, make sure that you have the motors hooked back up in the correct polarity (otherwise it spins in the opposite direction)
NOTES--
-Tiny tweezers don't seem to allow for enough force to push the retainer onto the shaft
-A standard screwdriver of comparable size to the provided phillips head screwdriver may allow for more pressure to be applied
-The retainers like to spring off of the shaft when pressure is applied in the wrong place-- hence the clean surface to find them when they do.
-I can't seem to find anywhere that sells only the servo retainers, so if you lose them, you may need to purchase the entire servo assembly. :(
-I know check these retainers as both pre and post flight checks to ensure that they are securely into place. They seem to like to pop off during very hard collisions (which is how mine came off)
Jan 24, 2009 | RC Toys
Left goes to the right
youre holding the remote upside down. Turn it arouns d - problem solved.
Dec 28, 2008 | Airtronics Toys
Toys Logo
54 people viewed this question
Top Airtronics Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Airtronics Toy Expert? Answer questions, earn points and help others
