Question about Sport & Outdoor - Others
Won't start. Changed plug, but still won't start. Gas mix contains fuel stabilizer, but it's been in the blower for about 8 months. How do I clean carburetor? Bob
  • 2 more comments
  • rvandoren Dec 30, 2010
    Hello Guru, Operator's manual says model no. 38190-3900001 & up, also model no. 38195-3900001 & up CCR 1000 snowthrower (Toro). Thanks for getting back to me. The manual does not refer to number of cylinders but it does say that it is a two cycle engine. Recoil start. No electric starter. Sorry for my ignorance.
    I took this snowthrower into the shop maybe five years ago when the primer was cracked and had it gone over. I replaced the plug two years ago and it started right away. It's probably time for some maintenance work, and I would like to save some money by doing it myself. I can order the carburetor rebuild kit on line. Do you think it's also a good idea to buy a shop manual? After all, I really need to know what I'm looking at. Let me know. It will take some time to let you know how all this works out. I could also buy the kit from the local Toro dealer and give it a try without the manual. What do you think? Bob
  • rvandoren Dec 31, 2010
    Hello ledsled378, I'm working all weekend long, and I won't be able to try this until Monday. I will have to get back to you about the results next week. Thanx for the advice. Happy New Year! Bob
  • rvandoren Jan 13, 2011
    My neighbor helped me out by taking off the carb and the needle valve and cleaning it. We have it running. Sorry it took so long to get back to you. Bob
    Thank you for this information. Bob
  • 2,841 Answers
You can download the manual from Toro, but they have several for the CCR1000 with different serial number ranges so I can't provide you with a direct link to it.
Here's how you get it:
Go to http://www.toro.com
On the left side in the Products and Support area, select "Homeowner"
In the top menu bar, select "Customer Care" and you will get a popup window.
Select the "Manuals & Parts" tab in the popup window.
Select "Advanced Search" (The CCR 1000 doesn't come up in the regular search)
Change Product Type to "Snowthrowers" and type "CCR 1000" in Product Name.
Click Search
You will see a list of manuals for specific serial number ranges. Select the manual that your serial number falls between. The manual is in downloadable PDF format.
After getting the manual and before doing anything else. remove all the old fuel from the tank. You can do this by removing the fuel line coming from the tank to the carburetor. Drain the tank replace the fuel line and refill it with a fresh 50 to 1 mix of fuel. Add 1 ounce of Seafoam Engine Treatment to the fuel. You can get Seafoam at most auto and marine parts stores and some Walmart stores. Now replace the old spark plug. Just remove the old one and take it to a auto parts store for a replacement. On the bottom of the carburetor you will see a round metal bowl. On the bottom of that bowl you should see a drain plug, Remove that plug and drain the bowl. Also buy a can of starter fluid. After you have drained and replaced the fuel and spark plug, spray a small amount of starter fluid into the breather. Attempt to start the engine. It will fire and start but may not run long. If it stalls spray a small amount of starter fluid and try again. If after 3 or 4 attempts it does not continue to run, you will need to remove the carburetor and clean it out. Unless you are skilled this is best left to a professional.
Posted on Dec 31, 2010
  • 1,514 Answers
When fuel is left in a carburettor it forms a gel in the jets. If this is thick the carburettor will need to be stripped down by a mechanic and the jets cleaned. Unfortunately this is a complicated job and not something that can be described in writing.
However before resorting to a mechanic there are a few things you can try that might work. First I presume you've put new fuel in the tank. Attempting to start it with this and leaving it overnight can sometime soften the gel if it's not too thick.
Next remove the sparkplug. Pour about 5ml (1 teaspoonful) of fuel into the opening where you took the sparkplug from. Dip the spark end of the plug in fuel so the spark gap is wet. Replace the plug and try to start it. The fuel you poured in should ignite and start the engine for a few seconds. This could be enough to **** the fuel through. Repeat the procedure 2 to 3 times if necessary. Don't be tempted to use more than 5 ml fuel as this could just flood the engine.
Hopefully this may solve your problem. If not I'm afraid it will have to go to a mechanic.
Posted on Dec 30, 2010
  • 2,926 Answers
Remove the carb and soak it in a solvent overnight, then use compressed air to blow out the tiny air/fuel passages. Purchase a carb rebuild kit that contains gaskets and orings as well as a new needle valve. What type of blower are we speaking of? Make and model number? 2 stroke engine?
  • 1 more comment
  • GetMeOttaHere Dec 30, 2010
    Your two stoke engine is most likely not starting due to fuel contamination in the carb. Removal of the carb, breaking it down, soaking overnight in a solvent, then using compressed air to blow out the passages is where I would begin. Purchasing a manual is always a great idea, and is also a good source for reference and repair. Check for spark with the spark plug removed from the engine. Place the plug on the engine so that the threads are against a metal part of the engine. This will create a ground...pull the starter rope.....and check to see if spark jumps from the electrode to the J shaped ground ******** the end of the plug.
  • GetMeOttaHere Dec 31, 2010
    Ok, but keep in mind that you have rated me on this solution before we actually came to a close. I will not be credited for all my input and time unless you accept ledsled378.
  • GetMeOttaHere Jan 13, 2011
    Sounds great. I would appreciate it if you could reate me on this solution. It is easy to do, and is important to us. Thanks for the response, and thanks for using Fixya.
My poulan 4018wt has been a hard starter from new. It started to act up out of the blue and started shutting off halfway into the cut and didn't always want to idle right. So I changed the spark plug,
I'd say the most probable culprit is the fuel.... I'd first try dumping the tank out, mixing fresh gas with the addition of a fuel stabilizer and start the saw. It'll quickly vent any old gas in the line and should begin to run fine with the new mix. If not, consider returning it to the service center for adjustment.
Never use gas that has sit on a shelf for months at a time as it becomes 'stale' (for lack of a proper term). Todays 'formulated fuel' can be a cause a bit of a problem for some small engines. Anytime you refuel, shake the can to remix prior to filling.
The oxygenated nature of the blended gas sometimes causes the chain saws to run a little 'lean'...meaning too much air to fuel ratio which could be a portion of your problem. A lean running saw will run hot and scoring of the piston or cylinder wall is possible. Some finely tuned professional saws need carb adjustments between the summer blend and the winter blend gas.
Mar 24, 2015 | Poulan Garden
My echo packpack blower won't start
How long has it been since its been started? If its been a while go to Home Depot and get some fuel stabilizer follow the instructions - if it hasn't been to long go to home depot and get a new spark plug and replace the old one as well as clean the filter -make sure to put fresh oil/gas ratio in the tank - use stabilizer if needed
Oct 25, 2012 | Echo 50.8cc Backpack Blower
2006 Honda Shadow won't start. Gas tank filled. Sat 8 mo. Gas leaked out but not into engine.No sign of external leak. into
1. Drain the gasoline.
2. Remove the carb bowl(s) and turn on the petcock to drain the fuel in the lines.
3. Clean out the carb bowl(s) and replace.
4. Refill with gasoline, add 1 oz of Seafoam fuel system cleaner (I'm not a sponsor, I just haven't found anything better) to each gallon of gas. This will stabilize your fuel as well as do a great job of cleaning out the carb(s).
5. Try to start it.
If it still won't start, begin the standard troubleshooting procedure by first pulling a spark plug and turning it over to ensure gas is getting to the cylinder. If so, replace the plug, hold the plug wire slightly away from the plug and turn it over to ensure a spark jumps between the wire and plug. If so, it starts getting complicated. Buy a manual for the bike if you don't have one and follow the troubleshooting steps there.
Jul 24, 2012 | 2006 Honda Shadow Spirit 750
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
McCulloch 320 chainsaw, won't start, removed spark plug, it was saturated in gas mix, how do I fix it? Guess I should ask if it's worth fixing first, lol...Thanks
If the saw had been sitting a while, especially without fuel stabilizer in the pre-mix,. change out the fuel and try a few more times.. it si a goof idea to allways use fuel stabilizer fro all the small engines..
Best regards
Ck
Sep 09, 2011 | McCulloch Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Blower/vac 24cc,185 mph, 385 cfm won't start. any suggestiong what i need to do.
many people are noticing problems with small engines now days, due to ethanol in modern gas, check the spark plug and clean or replace it, and be sure you have fresh fuel in the tank, stale gas will give you problems every time.your carb may be full of gelled gas and oil mix so a few shots of carb cleaner may help, And sears actually has a new product out that is an ethanol free 40:1 pre-mix with fuel stabilizer mixed in, it takes any guess work from mixing it yourself
Apr 12, 2011 | Craftsman Garden
What is the gas oil ratio of the ryobi leaf blower
Most Ryobi products made in the past 5 years use a 50:1 fuel mix. Check the fuel cap to see if it is listed there. The older Ryobi product used a 32: 1 fuel mix ratio and it was usually listed on the sticker that shows you how to work the choke. If in doubt, go with the 32:1 ratio. The only thing it will cause is premature fouling of the spark plug. Too little oil in the mix will cause premature engine wear.
50:1 is 2.6 ounces of 2 cycle mix to each gallon (U.S.) of gasoline.
32:1 is 4.0 ounces of 2 cycle mix per gallon.
I recommend to use a 2 cycle mix that is specifically designed for lawn equipment and contains fuel stabilizer. The ones with stabilizer will usually be .5 ounces larger.
Nov 30, 2010 | Ryobi Backpack Blower 25.4cc
I can't find an oil reservoir on this model ? Shouldn't every engine need oil ? I can't find the dipstick, Stuck, Harry
Welcome to the wonderful world of 2 cycle engines. Your McCullough blower uses a fuel mix to lubricate the piston. You MUST mix 3.2 ounces of 2 cycle mix to every gallon (U.S.) of gasoline.
If you run straight gasoline through your blower, you will RUIN the engine in seconds!
The fuel mix ratio is crucial to the lifespan of the engine. DO NOT GUESS.......MEASURE !!
I would also encourage you to purchase a 2 cycle mix that contains a fuel stabilizer. Gasoline starts to degrade in as little as 60 days, and a stabilizer will allow your fuel to stay fresh longer.
Good luck.
Oct 21, 2010 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
May 13, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Sport & Outdoor - Others Logo
60 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
