Question about HP Computers & Internet
One short beep one long beeb contin - HP Computers & Internet
    Genius:
  • 1,288 Answers
System ( motherboard problem) Is this a sunshine motherboard ~( HP media series)?
Posted on Dec 29, 2010
  • HP Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
2 Suggested Answers
  • 366 Answers
SOURCE: no video sveral error messages and one long beep
Have you changed memory recently, if not try removing one of the memorys and start again if no joy replace first one and remove secound one , see how it goes hope it helps, it sounds like a memory ffault to me.
Posted on Nov 30, 2009
Hi iam trouble my server hp dl 380 g7 no dislpy continue sound beeb
i need to know how many beeps long beeps, short beeps,
both short and long beeps, and how many times it happens.
than email me and i will help you resolve the issue
thank you rod
Mar 03, 2015 | HP Computers & Internet
Mobo beep
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HERE YOU CAN READ ABOUT THE BEEBING-CODES.
IF IT IS MEMORY OR VIDEO OR MOTHERBOARD.
Jul 04, 2013 | ASUS P6X58DE Desktop Board Intel Chipset...
Beeb codes
Beeps usally video related,,,ddr cards,,try removing one ,,with off ,,,then restart cpu,,see if helps,,if not repeat,,same with next ddr card,,,after putting other card back,,could be bad card,,good luck
Dec 20, 2011 | Dell Alienware Aurora-R3 Gaming Desktop...
Dell PE 1800 showed one SCSI 73G non critical state on a RAID 5 array of 3 disks. Shutdown the server, removed the SCSI disk and booted, server booted but continous beep sound, trying to rebuild the array...
Hi, try to renew the drivers and firmware from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PWE_1800&os=WNET&osl=en&catid=&impid=
Continuous beep related to ram ,try to remove ram and insert it, and if u still get beep change your ram.
Continious beeb sound is ram or cpu failure. Is the cpu fan spinning ??
If not the cpu is over heating.
Try to remove the ram modules and clean the contact points
with a piece of paper. Be very carefull when you do that !!!!!
And blow the dust out of your server, with a high pressure can.
Hope this was helpfull.
Mar 28, 2011 | Dell PowerEdge 1800 Server
No display and beep code
cpu on after one short beeb and long beep no display
Sep 11, 2010 | Foxconn 6627MA-RS2H Motherboard
I get 1 beeb followed by 3 beebs followed by 2 beebs then nothng happens dell diemension 8400
Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3) consists of one beep, a burst of three beeps. This beep code tells you that the computer encountered a memory problem
you need to reseat your memmry modules just remove them and place them back in the same or a diffrant slot this cold be loose connection by connecting them again you fix it
------------------------------------------------------------ if you dnt know abt it see this it will help you
http://support.dell.com/support/edocs/systems/dim8400/sm/parts.htm#wp1052406
Apr 10, 2010 | Dell Dimension 8400 PC Desktop
Sensor beeping continously in reverse
Try to clean rear parking sensors. Check also electric cables and connections, clean if necessary. Commons faults are sensors out of order. If one or more sensors faults you hear only a continous constant noise when you put in "R" gear. You need a VAS, VAG-COM, Bosch KTS, ... diagnosis scantool. The factory parking system will be scaned from errors with this instrument, and you will find exactly which sensors are out of order (for example: rear left center sensor, rear right side sensor break off, short to ground or short to plus).
Mar 28, 2010 | 2003 Volkswagen Passat
Can u help me?
check the video card of your system. if it is add on card , remove it and clean. if still error exist then maybe u need another VGA.
Jan 10, 2008 | Asrock 775VM800 Motherboard
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
