How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 488 Answers
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • Posted on Dec 30, 2010
    How can i open my old samsonite briefcase combination unknown
    1. Pull the sliding side latch to the side,
    as you would if you were opening the briefcase normally. Holding the latch in position, lightly roll your fingers
    down over each numbered wheel to identify which one is the tightest. The tightest wheel will give the least when
    you gently tug on it with your fingertip.
    2. Set the tightest wheel to "0." Check the tightness of the other two wheels; if they still feel loose, click the zeroed lock to "1" and feel the other two wheels again. Keep going in this fashion until one of the other two wheels feels tight. When one of the other wheels becomes tight, the first wheel is set at the correct number.
    3. Move on to the second tightened wheel, continuing to hold the side latch in place. Set it at "0" and check the final loose wheel. Keep adjusting the second wheel, as you did with the first until the third wheel feels tight.
    4. Set the final wheel at "0" and adjust it until the briefcase's top latches pop open. Make sure the sliding side latch is still being held in place.
    5. Reset the combination to numbers you'll remember in the future. Write them down and store them in a safe place, just in case.
    Jan 06, 2017 | Luggage & Travel
    I lost the combination and I need to know how to open it without the combination. Help!!!
    man I hate this when it happens . to destroy a perfectly good case . saw or grind the lock off .
    Dec 09, 2015 | Vaultz Locking VZ01353 SLR Camera Case
    Where can I get briefcase combination lock?
    Look for my tip on unlocking luggage with combination locks.
    Mar 26, 2015 | Delsey PARIS Hard Side Briefcase Business...
    Fix my briefcase combination lock
    Use Combination To Release Button--Factory is 00
    Feb 27, 2015 | Luggage & Travel
    Set combination lock
    Step 1:
    Locate the reset button, usually placed to the side of the combination dials.
    Step 2:
    Press the reset button and hold it while rotating the number dials to the desired combination.
    Step 3:
    Release the reset button after you set the numbers to the new combination.
    Try that :)
    Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
    HOW DO I SET BRIEFCASE COMBINATION ON STYLE NT0916A?
    There should be a reset pin hole near the unlock buttons of the suitcase. Just use a pin or something to reset the lock. Set your code, write it down, and there you go!
    Hope it helps!
    Dec 06, 2014 | Locks & Locksmithing
    Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
    I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
    How to Change the Lock Combination on Briefcase
    Oct 27, 2014 | Lands Phones
    I need to reset my combination on a pilot leather case
    This is how you generally change the combo on a briefcase
    1. With the briefcase closed put int the combination
    2. Slide the bottons in the opposite direction than you usally do to open it.
    3. Now set your new password.
    4. Slide the buttons back into place.
    5. If it dosent work the first time try it a few times
    6. If it fails try reposting with more specific model information about your briefcase
    Jun 28, 2011 | Office Equipment & Supplies
    Change combination on a presto lock on a briefcase
    Enter the correct code and open the case. Now push the button you use to open the case to the open position and hold it there, now push in the clamp and push the opener more and it will lock in place. Enter the new code and push the clamp part again to set it. Do to other side now.
    Sep 15, 2009 | SK Hand Tool (87018F) 9pc. Fractional...
    435 people viewed this question
    jasbo
    jasbo
