Question about Garden
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Posted on Feb 12, 2011
Hi, I have a Stihl FS88 trimmer with an auto cut 'bump' head. What diameter line should I use please.
Dave, I use the orange 2.4 mm .095" line, seems to give the best results. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-FS-88-108-Owners-Instruction-Manual.pdf
How to Rewind Your Trimmer Head or Sharpen Metal Blades
HOW TO Stihl String Trimmer Head Replacement
May 22, 2016 | Stihl Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Fuel hoses and filter need replacing and a spark plug for a Talon AT3351A line trimmer
The manual has some instructions for doing these tasks on the Talon At3351a Line Trimmer. Here is the link for the Talon At3351a Line Trimmer manual.
Jan 21, 2013 | Garden
Hi, I have a RYOBI ELT1100QFA electric line
electric line trimmers suffer from one major design problem
the motor has phosphor bronze bushes and the bottom bush goes dry from the grass juice and wears out and the armature poles out and lacks power to work
to get 5 years is good but it is time to take it in for a service or junk it and get a new one
Mar 30, 2017 | Ryobi Garden
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
I have a Talon electric line trimmer AT2309A and cant even seem to move the starting button to get it to work. Please help.
You need to move back the safety button on top of handle first. The safety button can be a bit stiff to move.
Nov 07, 2009 | 2006 Eagle Talon
Line trimmer not starting
The primer button may have a hole in it due to drying out. The little plastic bubble may not be priming the carburator prior to start. Leave on full choke and pull several times if still no start check for fresh and correct fuel/oil mixture if required. I am assuming this trimmer is not electric. If trimmer still fails to start or starts and runs for a moment and shuts off replace the primer button, the carb. is sucking too much air.
Sep 21, 2009 | 2006 Eagle Talon
Trimmer runs good but does not cut grass
I have had a similar problem with an edging attachment. The socket that fit onto the shaft was worn, and the shaft would just spin, creating a lot of heat right there, but very little movement, and it would completely stall when you tried to use it implement, even though the moter still ran just fine. The cure, I'm sorry to say, was to replace the implement.
Best regards, --W/D--
Aug 15, 2009 | Craftsman Convertible 25cc. Gas Line...
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
