Question about Compaq Computers & Internet
I use on my PC (Acer/Compac) My Pictures/Adobe Photoshop for the pictures I have. I have gone into the Properties section to add more information on each individual pictures. I than burned the photos onto a CD. When the CD is put into a MAC computer it does not read the added information in the properties section. How do I get the two computers able to communicate and the MAC pick up that added information.
  • Compaq Master
  • 7,733 Answers
  • When you go to the Connect to Server dialog, you may browse the names of computers that are on your local subnet.
  • You can connect to a server via its IP address or DNS name. If it is required or more convenient in your environment, you may also use other valid URL formats, such as:
    smb://ServerName/ShareName smb://DOMAIN;User@ServerName/ShareName
  • The name of the "share" (the shared disk, volume, or directory) must be specified. You will not be prompted for it.
  • You cannot type spaces as part of the share name when connecting. In place of any space in the share name, type: %20 .
  • When troubleshooting a connection issue, you can ping the IP address of the Windows PC using the Mac OS X Network Utility application (in the Utilities folder). A successful ping verifies a TCP/IP connection between the two computers. This is an important first troubleshooting step when there's no response or a timeout for a connection attempt, since SMB connections involving a Mac require TCP/IP. However, a successful ping does not mean the SMB service is also working or available.
  • Check Microsoft support resources for information about setting up file sharing on your Microsoft Windows-based computer. These may include Help files installed on your PC or the Microsoft online Knowledge Base. For example, see this article for Windows XP information: How to use the Simple File Sharing feature to share files in Windows XP.
  • When troubleshooting an SMB connection issue, use Console, which is located in the Utilities folder. These Console logs may help advanced users identify an issue: private/var/log/samba, private/var/log/kernel.log, system.log . Note that some log files only appear when logged into Mac OS X with an administrator acccount.
  • If you are connecting to Windows XP, make sure that the Internet Connection Firewall settings are not interfering with your connection. SMB uses ports 137, 138, 139, and 445. These ports should be open on the Windows XP computer. This may require "Advanced" configuration of the XP firewall.
  • If you are connecting to a Windows SMB resource, check to see if the firewall is blocking TCP ports 137, 138, 139 and 445. After trying the above steps, you may perform advanced troubleshooting by inspecting log entries in the Event Log of the Windows SMB resource (if you have access to it), and/or the Mac OS X computer's relevant logs in the Console application. If those steps do not help identify the issue, or you do not want to perform advanced troubleshooting, than you should contact your network administrator. It may be necessary to contact your network administrator in some situations in order to grant access to your Mac from the SMB resource, or its host network configuration.
  • Mac OS X uses SMB only over the TCP/IP protocol, not the NetBEUI protocol.
Posted on Dec 29, 2010
Serial number: 1045 - 1087 - 8529 - 1935 - 6265 - 9401 activation number: 0097 - 4717 - 5667 - 4100 - 8313 - 2438 - 6356 activation tipe: nirmal 93: - 8 please, send me authorization code
use keygen 100% works!!!
keygen photoshop cs2: http://www.dailytipz.com/wp-content/uploads/2008/12/adobe_photoshop_cs2_keygen.zip
For Adobe Photoshop Cs2
Note: Don’t Close This keygen
Note: Don’t Click Generate Serial Number
Open Adobe Photoshop keygen befor when you Install Adobe Photoshop Cs2.
Add This Serial Number When You Install
After installation active adobe photoshop by phone
Abobe photoshop display a activation number
Add activation number in adobe photoshop kengen
Your Authorization Code Display in Adobe photoshop kengen Authorization Code menu
Copy This Code And Past into your Software
Your Work Is Commplete Enjoy Adobe Photoshop Cs2.
You can see how it Work see this pic.
Apr 01, 2010 | Adobe Photoshop CS for PC
Can't get pictures from Photoshop Album Starter 3.2.
If you can see your photos on the Album timeline then this means that the thumbnails have been created OK so it should be that your jpegs are on you PC somewhere do a search for one of the filenames on you r C: drive to see if they can be found, this will tell you the folder that they have been saved in if you want to can then copy them all back onto your SD Card.
The default folder for import varies you may have asked for them to be copied to an obsure folder location the search method is the best way to see if you can recover them.
Hope this helps
Sep 28, 2009 | Adobe Photoshop CS2 for PC
Watermarking several pictures at once w/CS2
try using ACTIONS. once recorded they exactly do the same thing whnever u want. Need further assisstance? get back here
May 27, 2009 | Adobe Photoshop CS2 for PC
Digital pictures: want to add background with my G2 & Photoshop L
First you need to "cut" kiten out using the lasso tool, the quick selection tool, or the magic wand and delete the remainder of the picture by hitting the delete key, then you can put the picture of the kiten on any backgroud you choose.
Mar 18, 2009 | Adobe Photoshop Elements 6: Windows
I want to learn the basic of photoshop cs2 .
There are also the "Dummies" books, and Adobe publishes an excellent guide called "Classroom in a Book" for Photoshop.
Check Amazon.com for great prices on books of this kind.
Feb 26, 2009 | Adobe Photoshop CS2 for PC
Free trial to Adobe Photoshop expired as I just finished downloading pictures
If you had downloaded a trial version of Adobe in June and the program expired one day later you can fix by installing the official fix from Adobe below.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb403598&sliceId=1
If you had the trial for the term and the software expired then you would need to license it in order to use it after the trial period. However, you should still be able to access your pictures - often times they are stored within the My Pictures folder in My Documents.
Jun 13, 2008 | Adobe Photoshop 7.0 for PC
Enhance pictures
You don't need to buy photoshop realluy, you can download for free from this site. http://www.adobe.com/products/photoshopalbum/starter.html
Nov 01, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Adobe photoshop album starter edition 3.0
Photoshop Album Starter Editions (PASE) doesn't 'store' photos. When you 'import' pictures, it only saves a thumbnail and remembers the location of the original file. It isn't designed as a filing solution. You have to locate and keep track of your original files. Here's an article explaining it in more detail.
http://www.startereditionuser.com/?page_id=6
Sep 22, 2007 | Adobe Photoshop Album 2.0 for PC
History brush tool
The history brush tool is used to draw special effects using previous snapshots of an image. The best way to learn about it is to play with it, look at the information on the following links an experiment with your own pictures. http://livedocs.adobe.com/en_US/Photoshop/10.0/help.html?content=WSfd1234e1c4b69f30ea53e41001031ab64-7805.html http://www.espressographics.com/text/historybrush.html Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 04, 2007 | Adobe Photoshop CS2 for PC
Computers & Internet Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
