Question about Dewalt DW421 5'' orbital sander
I dropped the sander and now it no longer works.
    Problem Solver:
  • 16 Answers
What do you expect?
Probably mostly plastic & cheap
See if Home Depot will take back
Posted on Dec 30, 2010
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Why the oil will come out from the sander? how many oil drop must regulate the regulator
Oil coming out of the sander indicates that too much oil is flowing into the the supply air. The rule of thumb for oiling an air motor is 1 drop of light machine oil per minute, per 10 cfm of air.
Jan 16, 2014 | Dynabrade Air Tools & Compressors
Parts for a 335 sander (6
Part is no longer produced. I am going to adapt a 6" dewalt pad by drilling new mounting holes. (The Dewalt pad has 4 holes.)
Jul 18, 2012 | Porter Cable Tools & Hardware - Others
Sander disc no longer "sticks"
Most commercially made disc sanders have replacements pads whether they are hook and loop type or the rubber. If you go to the manufactures web sit and look up your sander, it will usually be listed somewhere. But you might have to call an authorized repair center to find the part number to order.
Jun 07, 2011 | Vacuums
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
Oct 15, 2010 | Dewalt DW411 quarter - sheet palm grip...
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Jun 12, 2009 | Tools & Hardware - Others
Air sander problem
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools
Aug 27, 2008 | Taylor Pneumatic: Straight Line Sanders:...
Dewalt DW421 5'' orbital sander Logo
102 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
