Question about Alpine 600W Class D Mono MOSFET Amplifier with Adjustable Crossover
Amp Was Extremely Hot and I Have Now Lost All Sound
The other day I was running some intense bass through my Alpine 600W amp to my 2 10" Slim 1000W Kenwood Excelon subs. From the first day it was installed, I had a problem with the amp going into protection mode due to the gain being turned up too high. I had since turned the gain down about half way with no problems, although one hot day 2 weeks ago, I had the amp shut down due to overheating, turned off the power, turned it back on, and had it working fine again. However a few days ago, as I was driving, I could tell the bass was becoming more distorted, and a funny "aroma" was in the air. I can only describe the smell as being similar to freshly poured cement. Then, the sound disappeared. I went to check my amp, only to discover that it was extremely hot to the touch, but the blue power light was on, revealing that I was getting power to the amp and the fuses were not blown. I allowed the amp to rest for a couple of hours with no luck. It's been three days and I am still not getting any power to the subs. I attempted to readjust the amp's gain again by turning it down with no luck. Any solutions?
  • 2,130 Answers
Where was the smell coming from? The amp or the sub?
Do you have an ohmmeter to check to see if the sub's voice coils are still intact? Can you try driving the subs with another source to verify they are ok? We need to eliminate the variables here.
If the subs are okay then it's obvious that the problem is in the amp. I'm not sure if there are any protection devices internal to the amp, but I am sure if you remove the cover from the amp and if it was amp that was producing the burnt smell, you'll have no trouble visually identifying where the problem is in the amp. Most likely you'll find a part that is discolored or black & burned.
Usually a smell like this from a solid state device indicates a component has been overheated and if run long enough in this condition will fail.
- Jim
- Jim
Posted on Jul 07, 2008
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
I have a 1000w amp but it got burned why??
I'm sorry but your problem was a little confusing. Your speakers worked fine, you hooked up a 1000W amp and now you cant hear the sound ?
Then you say "they say because the wires were connected wrong in the amp it burned" does that mean your amp burnt out ?
Please post back and sort these facts out for further assistance.
As of right now im not sure if the problem is with the speakers or the amp itself.
Oct 01, 2009 | Alpine MRD-M1005 Car Audio Amplifier
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
ALPINE PDX 1.1000
well you would have to look into the ohms of the amp compared to the ohms of the speaker. If the ohms are different you would have to hook them up in a different way. check the RMS on the speaker as well as the amp, this can also be sufficed by wiring it different if ohms match up properly! Hope this helps you out and if this is not the case let me know.
Feb 28, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Car amplifier wont turn on
Your best bet is to call Alpine directly at: 1-800-832-4101
Jul 15, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine 600W Class D Mono MOSFET Amplifier with Adjustable Crossover Logo
166 people viewed this question
Top Alpine Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
SHARCNET-USA
SHARCNET-USA
Are you an Alpine Audio Player and Recorder Expert? Answer questions, earn points and help others
