Epson CX5400 Scanner fault - Office Equipment & Supplies
  • 691 Answers
Make sure the head lock is released
Posted on Jul 07, 2008
Printer error says to release transportation lock before turning on but can't find this lock
Lift the scanner lid and you'll find it on the left side.
Ref: http://www.manualowl.com/m/Epson/CX5400/Manual/75434?page=2
Jul 28, 2013 | Epson Stylus CX5400 All-In-One InkJet...
I lost my installation software for my epson stylus cx5400 scanner/printer. is there a download site foir this software. i am a student and need to finish research papers and need the device tonight
Please find the driver from the below mentioned link
http://drivers.softpedia.com/get/PRINTER/OTHERS/Epson-Stylus-CX5400-Printer-Driver-54aA.shtml
A positve feedback is expected along with your 4 thumbs
pp
Nov 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Scanner will not work
may be the cable is not good try and use another cable
Oct 16, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Nothing happens when i hit the scan button on my epson cx5400
you need the proper driver for the scanner which is compatible with your operating system.
what is the full version of your operating system?
You can download the twain driver off the support.epson.com site.
if you need more assistance please let me know.
May 12, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400. I have 2 and both are giving 'error'red light and message 'scanner error' see documentation and caqll service if necessary'. I have rung an Epson Service centre and they say it is not...
Please follow the steps below to resolve your issue.
1. Turn off the printer.
2. Lift the scanner cover.
3. Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4. Turn on the printer, and the error should be cleared.
Update me if you are still getting the error message.
Apr 28, 2008 | Office Equipment & Supplies
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
175 people viewed this question
jasbo
jasbo
