Question about Bosch Washing Machines
Bosch clothes washer model WFK 2401 with error code 06. Already cleaned the pump trap several times but did not solve the problem. Please advise.
  • 3 more comments
  • jsamanie Dec 30, 2010
    Hello Macmarkus,
    Thanks for the reply. I ran the self diagnostic/test program and got the 06 error code. The door latch and door hinge alignment seem good and the door closes properly. Is it hard to replace the faulty door lock mechanism? The Bosch repairman cost $185.00 for the first 30 minutes and $20.00 for each 15 minutes after that. I am wondering how hard it is to change the door lock mechanism myself? My e-mail address is jsamanie@pacbell.net
    Regards
    jsamanie
    Hi Macmarkus,
    We ordered the Door Lock Item #1159500 and will receive it on 1/3/11. Have a happy new year.
    Thanks
    Hi Macmarcus
    We ordered the Door Lock Item #1159500 and it will be delivered on 1/3/11. We will let you know how it goes.
    Thanks and Happy New Year
  • jsamanie Jan 04, 2011
    Dear Macmarkus
    I installed the new lock assembly and that fixed the error code 06. I just ran a load and it performed the whole cyle without errors.
    Thanks for all your help.
    Regards
    jsamanie
    The solution was very helpful. Macmarkus diagnosed the problem correctly with detailed instructions on how to replace the faulty part. I ordered the part and installed it myself in about 10 minutes. I probably saved between $200 and $300 conservatively. Thank you very much.
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description it sounds like a faulty door lock mechanism. As you may or may not already know the 06 error code for the WFK2401 Bosch washer indicates an error in the lock has been detected.
This is from the Bosch service tips I have, so you should be able to check it with this info...
I also have this available to you in "pdf" and I can send you if you want to provide an email address since the "pdf" cannot be attached or sent via these post's.
You can also run a self diagnostic/test program by following these steps I've laid out, then let me know what you find...I suspect a faulty lock as I alluded to though.
To enter test program for WFK 2401 washers:
1) Set cycle knob to any "X" (reset) position
2) Press and hold Pre-Wash and Start buttons at the same time. While still holding Pre-Wash and Start buttons, turn unit on by pressing On/Off button.
3) Keep holding Pre-Wash and Start buttons (only) until digital display comes on (~ 5 seconds).
**HINT: Turning washer off at any time will end test program**
When test program has been entered:
Start light will flash
Digital display will show 00 for no faults or will show fault codes below:
Let me know what you find as I said or if you require further assistance. Thanks for choosing FixYa for your repair inquiry and good luck
please rate the solution I provided accordingly.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Dec 30, 2010
    Hello again,
    The changing or checking of the door latch assembly actually isn't very difficult...in my opinion, and depending on your mechanical abilities it likely wouldn't be that hard for a do-it-yourselfer...with help.
    **The first step is to unplug the unit from the dryer, or the wall depending on your particular set-up...safety first of course**
    The door switch itself should be held in place via two screws which should be visible when you open the door to the basket, but first remove the spring which holds the door seal/boot gasket in place,
    i.e
    Once the spring is removed, you can fold the boot gasket back away from the front panel, this will allow you to reach in and remove the door latch assembly...with the wires and fasteners from the front removed as well of course.
    It should look like this image...
    Front view:
    Top View:
    This part is available at on-line supplier "repairclinic.com" for around $35USD and their part is # 1159500.
    Let me know if any of this is not clear or you need my help in any manner. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Great ! I will watch for your progress report/results, or if I can help in any manner let me know.
    Good luck to you and Happy New Year too.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jan 04, 2011
    I'm glad you're back up & running, all in all you likely saved $200 or $300 conservatively. Good job !
    Hope you will take a moment to rate the assistance you received here, and thanks again for choosing FixYa.
    Regards,
    Macmarkus :)
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
I have a WFK2401 Bosch washing machine it is not spinning the clothes dry but the water drains from the machine. I did clean out the pump and trap but it is still not working. What do you think it is?
WFK2401 Bosch washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 21, 2011 | Bosch WFK 2401
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
I have a Bosch 2401 washer. When I set the cycle and push the On button the Pre Wash, Rinse Plus, and Power Wash lights flash, and CL appears on the display. Pressing Start does not work. I tried the self...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages, look for block at end of exit hose. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Jan 23, 2010 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
1,053 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
