Question about Jumbo RC JUMBO HELICOPTER
I need the adapter can you tell me what the voltage is
    Scholar:
  • 35 Answers
Imput-120v AC
Output-7.2 volt DC
You are not quite out of the woods yet as you still need the correct plug adaptor on the end of your power supply. If you are handy with a multimeter, the leads could be identified by yourself and the matching Male/Female plugs connected to the wire ends.
Posted on Jan 10, 2011
Toshiba 1905-s301 wont run on just ac power
Check your AC Adapter for voltage output using a multi-meter. If voltage is lower than stated replace Adapter. When replacing adapter verify Amperage is same before purchase.
Dec 18, 2013 | Toshiba Satellite 1905-S301...
My samsung galaxy pro GT-B7510 battery Not getting charged by Charger and only by USB cable and power lossing immediately i remove cable, how can i solve ??
Check the mains power adapter with a multimeter. Plug the adapter into the wall mains socket and then measure the voltage on the adapter plug, the voltage should be slightly higher than the voltage that is printed on the adapter. If you get a low reading or zero reading the the charging adapter is faulty and needs to be replaced.
Mar 29, 2012 | Samsung Cell Phones
Why won't my laptop switch on any more?
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Mar 31, 2011 | Packard Bell EasyNote A7 718 Notebook
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Laptop not powering
Sir,
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOWPUT IN BATTERY
AC power adapter How the AC adapter worksThe most common type of AC power adapter involves a small box, withone wire to go to the computer and another wire to go to the wall.There is usually an LED light on it, to tell you that it is on. (Is itlit on yours?) By the way, Apple notebook power adapters often have anLED that is actually built into the side of the computer, not into theadapter box, so obviously it won't light up when it's not connected tothe computer.
The power adapter box does several things. It lowers the voltage from the wall's 120 volts AC to typically 19 volts DC (it will be labeled with the exact voltage). It includes some power noise filtering. It often includes an automatic circuit breaker or overload detection. If this gets tripped, you can generallyreset it if you unplug it from everything for a few minutes.
You can measure the voltages on your AC adapter with a multimeter. When it is unplugged from the computer but still plugged in to the wall,it is normal to find that the voltage may be 1 to 3 volts higher than theprinted output rating.
Troubleshooting: AC Power adapter LED is off when you plug the adapter into the wall but not into the computerHas it been overloaded? Is the power strip turned on / is the outlet working? Is the cord from the adapter to the wall fully plugged in on both ends (try wiggling)?Your adapter may be fried- try borrowing an indentical adapter from a friendand seeing if that one will work in it's place (but do not plug it in to your computer, or you might fry your friend's adapter).
Troubleshooting: Check output voltages with a volt meter/multimeterFor those of you with circular connectors, your task is easy. Measure the voltage between the inside and theoutside. A diagram on the adapter's label will tell you which should be positive and negative
For those of you with the 3-pin Dell power connectors, I don't have a diagram for you yet, sorry.If you try measuring each of the three possible pairs of pins, you should get 20 volts between oneof the pairs.
Power distribution inside the laptop How laptop power distribution worksvoltregulator.jpgOkay, the power comes into the plug on the back of the computer. This connects it to metal tracesinside the mainboard of the computer. These will be connected to voltage regulatorswhich often output 5 volts, 12 volts, 3.3 volts, and the CPU voltage; they sometimes look like the image at right.
These will be connected to cylindrical capacitors distributed throughout the mainboard. Capacitorsact like tiny, fast batteries, supplying extra power where needed to maintain a steady voltage during high demand.
Finally, power goes to all the devices that need it.
Power for the LCD display is usually done seperately. Generally, LCD backlights require high voltage to operate.A component that might be called a power inverter will step the voltage upto what is needed for the backlight. Sometimes this inverter is a discrete andreplacable component, and sometimes just a chip on your mainboard. It is also involved in the brightness control.
The battery is an important part. It supplys power to theinput-side of the voltage regulators, just like the power from the AC adapter.Additionally, there is a charging circuit, which uses the power from theAC adapter prior to the voltage regulators, to charge the battery. (By the way, this is why the AC adapter voltage is always rated higher than the battery's rated volatge-- you need higher voltage for charging.)
There is a separate page exclusively for Laptop Battery Problems.
Short circuitsAnywhere in your laptop, physical or electrical damage can cause a short circuit.A short circuit will consume all available power, causing your laptop to not turn on.If your power adapter LED comes on when you plug it into the wall, but then goes offwhen you plug in the laptop, you probably have a short circuit.
Troubleshooting short circuitsAn ohm-meter / multimeter will read less than ~3 ohms when you measure theresistance between sides of power going into a short circuit. When measureing betweenthen power pins going into the back of your computer, consider the 2 pins whereyou expect voltage to be applied by the AC adapter. If the resistance indicatesa short circuit, this is bad.
A common trick to help isolate possible problems is to try to removing anything that mightbe a short circuit. Take out the battery, the hard drive, the DVD/CD drive, the floppy drive, PCMCIA cards, USB devices,miniPCI cards. See if the computer will then turn on.
You might have luck with a thermal imager (see story below) to find a hot spot caused by theshort circuit.
Spilled liquidLaptops exposed to small amounts of spilled liquid are repairable in some cases. Liquid can cause the following types of damage:
  • Short circuit due to wet liquid (problem goes away after liquid evaporates)
  • Short circuit due to dried liquid residue
  • Corrosion (especially bad with soda such as Coke or Pepsi)
  • Electronic components damanged by above short circuits
Immediately when a spill occurs, you typically want to turn off thelaptop, turn the laptop upside down (so the liquid goes out the sameway it came in), remove the power and battery, and allow to dry atleast overnight.
To remove dried liquid residue: Try removing the keyboard andcleaning any components that have dried liquid, by using distilledwater and Q-tips.
Computer turns off randomlyYour computer can turn off due to: power overload in the AC adapter,overheated processor / clogged fan,overheated battery, pushing the power button, Windows telling it to,the BIOS telling it to, loose wires (especially the power cord), orintermittent short circuits.
The most common problem is cooling. Try going somewhere air conditioned. Notice if the fan isbroken or clogged with dust (common older HP problem).
Thanks
Good Luck
Aug 17, 2009 | HP6710b 2.1GHz 15.4 160GB 5400 PC...
I bough a brand new Singer embroidery from America (I live in Australia). When it finally arrived I eagerly pluged it in using a regular plug adapter. It turned on for an instant and then quickly fizzled...
Unfortunately you need an 240AC to 110AC adapter for this kind of equipment (try **** Smith). A plug adapter does nothing to change voltage it just lets the plug fit the power point, this is ok for some smaller electronic devices that are built to automatically sense the voltage. There is usually a sticker in small print on the device that will tell you what voltages it will take. I can't tell you whether its been damaged, but by going by your description it doesn't sound good. You can try an AC to AC adapter but it may not work now. I'd ask the supplier for a replacement as they should have known that Aus is 240V.
Oct 07, 2008 | Singer CE-200 Quantum Futura Computerized...
Need charger
What needs to be done here is goto the local Rat Shack, and purchase a universal power adapter for your specific voltage and amperage. Remember to bring your device into the place to match up the tip with the power socket on the device. Tell them you need 1500 milliamps and tell them you need 9 or 12 volts.
The cost should be no more than fifteen dollars total for adapter and tip, usually the tip comes with the purchase of the transformer, and dont purchase one with a variable voltage, just a fixed voltage if possible you can use 9 or 12 volts but it has to be 1500ma(which is 1.5 amps).
May 15, 2008 | Televison & Video
Please Tell Me That I Did Not Damage The Router
that linksys router u purchesed in out side america right might be u r using this in asia pasific so the power adapter u got with the box its comparatable only in USA the in put and out put voltage is different
out put voltage is -->12V, 1.0A Max
in put voltage is -->100V - 240V>so u need to get a power convertor u can get it in local market rate me solved if its helps thx
Nov 25, 2007 | Linksys Wireless-G WRT54G Router
AC/DC Adapter
Hi, You would need an adapter that puts out 12 Volt DC, Output Current: 3.3 Amp and the Center Positive Power Tip (Output Power: 40W). The original ViewSonic adapter is M/N: UP06031120A Hope this be of some help/idea/ Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Jumbo RC JUMBO HELICOPTER Logo
100 people viewed this question
Top Jumbo Toys Experts
ray gallant
Are you a Jumbo Toy Expert? Answer questions, earn points and help others
