Question about Philips 42PF7320A 42 in. Plasma HDTV
I have a Philips 42PF73210/37 42" Plasma. I have approximately 3" or 4" vertical black strip on the left side of the TV. The rest of the TV seams to work, Does anybody know what this could be and how to fix it.
  • drummer536 Dec 30, 2010
    I will get you an image later tonight, I am not at home right now.
  • 4,889 Answers
Can you please get me an image so that I can see for myself what exactly it looks like? You can upload the image to imageshack.us and get me the direct link.
Sai.
Posted on Dec 30, 2010
  • eagle338
    eagle338 Dec 30, 2010
    Ok. No problem. I will respond as soon as I get it.
I have a black vertical line on the left side of my plasma tv how do i get rid it
Those lines signify a bad display panel. The only thing you can do is replace the panel which can be hard to find and very expensive. Sorry to say, sounds like your panel is shot
Jul 08, 2011 | Philips 42PF7321 42 in. Plasma HDTV
Anyone know why the Samsung PN50B550 50in Plasma would have a vertical strip about 2 inches long on the far left side that keeps going to static/out of tune. The rest of the picture is fine. I've checked...
I had this issue..Go to Menu and go to the burn in troubleshooting and run the scrolling feature..Scrolls whites and darks..Run for an hour..I had it on both sides..From watching 4 X 3 pic, image retention..Should clean up fine
Mar 02, 2011 | Samsung PN50B550 50 in. Plasma HDTV
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
I have a 42'' Philips Plasma, I have a 4'' vertical black strip on the left center of tv?
PDP defect .Try to get warranty via the shop where you bought the set.A complete PDP is very expensiv.
Aug 03, 2009 | Philips 42PFP5332D 42 in. Plasma...
Black Vertical strie on plasma TV
I think you have a frame fault on the tv. If you are capable check the picture frame board first. If not find a competant technician. Good luck.
Oct 02, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Philips 42PF7320A 42 in. Plasma HDTV Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
