Question about Pioneer DV-C503 Multi-disc DVD Player
IT WILL OPEN AND SHUT IMMEDIATLY - Pioneer DV-C503 Multi-disc DVD Player
  • Pioneer Master
  • 6,771 Answers
There is probably a loading belt that has become stretched and the tray is not completing the cycle, " meaning it is not opening all the way and ends up closing just as fast " this a tricky repair best suited for a professional.
Posted on Dec 29, 2010
My merc 40 hp four stroke shuts down immediatly after start up reves to 3000 rpm them shuts down
I had one that did this and it turns out it was the plug on engine that ran to dash switch had a corroded connector in it , vibration from engine made it shut engine off !! just like the key !! it would start right back up run a minute then shut off again !
Nov 08, 2016 | Cars & Trucks
95 Ford Taurus wagon 3.0. bumped in the rear and car died immediatly. Cant find the enertia switch. Found some kind of black box inside the drivers side rear quarter panel, but it has no reset swetch.
The emergency shut-off, fuel reset, or inertia switch - all referring to the same thing - is typically located in the back right corner of the vehicle.
Sedan: Open trunk lid, look to right side near fuel filler port, pull back the trunk liner to expose the switch.
Wagon: Open hatch, look to right side near fuel filler port, open access panel.
Recessed into the top of the switch is a red button. If tripped, then push down until it resets, or clicks back into the on position.
Sep 24, 2013 | 1995 Ford Taurus
Is oil light suppose to come on before starting bike just changed oil and filter theres 3 holes in window for oil
When You Turn The Switch To The On Position. The Oil Light Should Be On This Basicly Shows That Bulb Is Good. When Engine Starts And Is Running The Light Should Go Out Immediatly Indicating Oil Pressure.If The Light Does Not Go Out Shut Engine Off Immediatly And Investigate.OIL Level , SENDING UNIT, Loose Wire At SENDING UNIT.
Mar 17, 2013 | 1995 kawasaki GPZ 1100
03 ford powerstroke fuel lk. on top of engine, behind the fuel filter housing,fuel sits on top of valley area. can't see any lk. must be slow. cleaned area, can't see any lk.
It ended up being the fuel filter housing drain / shut-off valve. waited for the engine to cool overnight/started engine & rechecked immediatly before engine started warming up & it leaked immediatly. It apparently was a cold only leak. thanks for your attention..
Jan 07, 2010 | 2002 Ford F250 Super Duty SuperCab
Engine Starts, then immediatly shuts down
mass air flow sensor, or idle control valve.
Apr 28, 2009 | 1989 Dodge Raider
LG 50" plasma will turn on then shut off shortly there after.
Unplug the power from the power outlet and let it sit for a few minutes. Then plug it back and it should work normally.
Apr 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Onkyo SR502 Shuts off by itself
It is not a blown fuse. Your baby is in its ***** throes! It is fubar. You have either a damaged power supply or blown output stages (since sounds horrible it is probably this).
Sep 17, 2017 | Onkyo TX-SR502 Receiver
Disc door will not stay closed
try blowing dry air by the disc port, to clean the reading eye(pickup),(get a can at radio shack),prices of today put you to think abouth repair or buy a new one, you decide...good luck
Aug 09, 2006 | Apex Digital GT1417DV 14 in. TV/DVD Combo
Pioneer DV-C503 Multi-disc DVD Player Logo
284 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
