Question about Whirlpool LER5636P Electric Dryer
Looking for a wiring diagram for whirlpool awz135 tumbledryer
  • somersparks Jul 22, 2008
    Thanks for the reply but i did it the old fashion way and traced the circuits - found fault- (Heating Element) and now running again-
    i have traced fault to Heating Element and replaced it , All working fine now thanks for your advive but no plans inside my machine just had to trace the circuits with a meter untill i found the fault
  • 3 Answers
Don't know if this will help; I found one for my Whirlpool dryer inside! It was in a clear plastic bag taped to inside of front cover, I cam across it whilst I had the rear panel off.
Maybe take off front/rear panel after unplugging, you may find one inside?
Posted on Jul 10, 2008
Whirlpool Tumbledryer AWZ-121/3 OVERHEATING PROBLEMS
When was the last you cleaned the hose leading off he back.
Pull the dryer out and remove the exhaust hose (probably held on with a hose clamp so you will need a flathead screwdriver.
Once it's off take the hose from a vacuum or shop ac and stuff it in there and get out everything you can. Do the same win exhaust hose, and from the front at the lint filter.
Jun 14, 2016 | Whirlpool Dryers
Whirlpool Washing Machine Whitemagic h70 Wiring Diagram
Can't seem to find one.
Is there a model# other than whitemagic h70?
I have had luck on parts places showing schematics when you start looking for parts in the machine.
Maybe that can work for you.
Nov 25, 2015 | Whirlpool Washing Machines
Got a whirlpool model wmh32517aw and I need a diagram on the wiring and components
Look on the back, contact manufacturing or go to the web site they have.
Jul 07, 2015 | Whirlpool WMH32517AW 1.7 cu. ft....
Contacted Whirlpool to obtain wiring diagram and they will not provide because it is only available to Whirlpool techs. Does anyone have a wiring diagram for Whirlpool model # GD5RVAXVY05
Just about every appliance I've ever owned or seen has a copy of the wiring diagram stuck to it someplace or folded up and tucked into a crevice someplace in the "service tech" area of the unit. Have you looked around the unit itself?
Dec 19, 2014 | Whirlpool Refrigerators
Whirlpool awz135 wont heat up
Check the circuit breakers and see if one has tripped.
There are two circuit breakers that run your dryer.
One does the heating element, one does the motor and controls.
Usually they are together side-by side in your "fuse box" wherever that is.
The circuit breakers may look fine , but still be tripped.
If you will switch them off and back on again, see if that fixes it.
It may take a few times, like 3 or 4.
Other than that, newer models have more thermostats and also a fuse.
Is it possible you could find an overheat element you missed, like not with the others?
Be blessed.
Be blessed.
Feb 18, 2013 | Whirlpool Dryers
Finding wiring diagram whirlpool refrigerators
take off bottom cover should be on back if not look around compressor they usually leave them stuck around there
Apr 12, 2010 | Whirlpool GD5SHAX Side by Side...
Hotpoint aquarius tumbledryer tdl30 not heating
Check that the breaker is fully on by cycling it all the way off, then back on again.
If problem persists, may be an open heating coil.
Dec 20, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
I need wiring diagram for whrilpool ler5636kq1. timer
Good luck finding one. I look at the wires. They are marked with the same letters as that of each dryer terminal. I have a plain jane dryer manual from whirlpool but I doubt it will help much.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool refrigerator ET18GKXHW0 NW power cord ripped out
The refrigerator should have a wiring diagram. Look in the grill on the bottom of the front of the refrig. Pull that grill off and a lot of times they are in there. Sometimes thay are taped to tha back also. You can buy a wiring diagram just like any other part from Whirlpool or sears parts center.
Sep 10, 2009 | Refrigerators
Whirlpool LER5636P Electric Dryer Logo
197 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
