Software will not install. Many attempts and same error message : Corrupted or incomplete file. VIOS MP4VCD1001 bought here in Mexico. Using Acer Aspire computer. What can I do to fix this problem?. Appears that they are not communicating. Thanks, Judy
  • 27,725 Answers
Ring your ISP internet sevice provider get them to check your modem for internet access online
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
hope this helps
Posted on Dec 29, 2010
Sim 3 into the future installation
What causes Extended Attributes Are Inconsistent Error Message error? The Extended Attributes Are Inconsistent Error Message error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Extended Attributes Are Inconsistent Error Message error?
There are two (2) ways to fix Extended Attributes Are Inconsistent Error Message Error:
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Extended Attributes Are Inconsistent Error Message ) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 20, 2014 | Computers & Internet
Sim 3 installation
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Aug 04, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Computer turns on but will not load windows. Freezes after gateway comes on. Plus cannot start in safemode
Enter the BIOS and ensure that the Hard drive is indeed being seen by the computer.
Open up the chassis side panel and ensure that all conections are making contact.
damnor01
Apr 14, 2011 | Gateway 3250S PC Desktop
Pc slow
Learn why is a pc running slow and how you can fix the issues from: http://www.whyismypcsoslow.net/
Feb 11, 2011 | Acer Aspire One PC Notebook
I am in the process of recovering my Acer veriton m275 but I noticed when it gets to the "restorng process" it stays 99% even if I leave if for the day...not sure what's causing so much...
First check on the computers operating systems compatibility to the software attempting to install should be similar computer systems to integrate. For example, Microsoft windows 2000 would least install on Microsoft millennium only mentionable example of compartilities in software's. Second, check on the available computer disk spaces to attain installations. Prior computer would begin installation without warning of compatibility malfunctions only never acquires complete installation. A later message of incompletes is common observance or messages of errors or spaces unavailable.
Feb 02, 2011 | Acer Veriton M275-UD5700W Desktop PC...
I have an acer one netbook /notebook---- computer freezes....worsenes w/tiime....sometimes it boots to windows then freezes,in safe mode .......still freezes....
CorruptedSystem Files
Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen
Dec 02, 2010 | Acer Aspire One PC Notebook
Error Tab
Turn off the, or better yet uninstall, the Acer Screensaver. Something you installed, possibly a screensaver program? has corrupted the Acer screensaver causing that error message. That add-on screensaver is notoriously buggy anyway.
James Smith
A+ NET+ Server+ M.C.S.E. CCNA
Sep 09, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
