Question about Microsoft Xbox 360 Console
E68 - Microsoft Xbox 360 Console
  • 67 Answers
More info
Posted on Feb 01, 2011
What is Frigidaire gallery dryer code e68
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Feb 13, 2015 | Frigidaire Dryers
Error code 68
Good Morning Mua_m7,
I see that you are having trouble with your Frigidaire washer giving you an E68 error code. The E68 could be one or both of two possibilities.
First, it could be the heating element. If the heating element goes out, this means that you would be unable to get the water temperatures to hotter temperatures.
Second, it could be something going on with the main control board inside your washer.
With you receiving the E68 error code, I suggest that you give your washer a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. When you restore the power, if you are still receiving the E68 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire Washing Machines
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
E68
The e68 error can mean a bunch of different things on an Xbox 360.
I have personally had this error and I had to turn the unit off, unplug it, disconnect the HDD, reconnect the HDD, plug it back in and power it on.
Fixed it like a champ.
Here's some useful websites that contain information on the e68 error:
http://www.ehow.com/how_5121542_fix-xbox-error.html
Thanks and please rate if this helps you!
Mar 29, 2011 | Video Game Consoles & Games
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works<did that twice<the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
What is e68 on a xbox
What you need to do is
1. rmeove the hard drive from unit then turn it on
Foolwo this link and what is is and how to fix the issue
http://ezinearticles.com/?Xbox-Error-E68---Xbox-360-E68-Error-Repair-Tips&id=2340222
thanks and hope this information does help please do leave your feedback and ratings.
Aug 11, 2010 | Microsoft Xbox 360 Console
Got system error E68-and a red light-this has happened after using a hard drive to save my game data-now can't find any data-would appreciate assistance!!!
I've got a permanent fix for Error E68 to help you out, But first ill tell you my XBox was dropped so it might have just worked for mine, i will be posting a vid on youtube by Nov. 5 2009 look for imthatstupidkid fix X Box Error E68 walkthrough
Oct 20, 2009 | Microsoft Xbox 360 Console
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
