Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Ice drips from the ceiling of the freezer
There are ice drips that start from the ceiling of the freezer cpmpartment and drip all the way to the bottom. There are "ice tracks" on both sides and a sheet of ice at the bottom.This keeps growing like cave formations and spreads to the grill areas over time.
When we turn off the fridge and clean everything out, water still drips from the ceiling of the freezer.
Can someone help?
  • AbedSham Oct 08, 2008
    This is a side-by-side built-in GE Monogram piece of junk. We have spent about $2,000 to fix this problem but to no avail (a similar new fridge is ~$7,000). I am spending no more money on this.
    I have to defrost the freezer (every 2 weeks) to prevent ice build up from the dripping water from the top of the freezer where the evaporator is. It seems that the pan below the evaporator overflows and water drips from top non-stop until chunks of ice form on the back wall of the freezer. The GE, Sears, and independent repair men came and went and none could fix the problem. Now I see that this is a design flaw!!!
  • AbedSham Mar 31, 2009
    I was told that this is a bad design but GE will not fess-up to to. I had the defrost pan replaced twice. The problem is still there. I have to manually defrost every 3-4 weeks. So, it is on my schedule to do this...over..and..over...hey I am starting to like doing this chore...
The problem as I found it to be was really like the post by 'studyecon' . There is a clear vinyl hose which exits the evaporator compartment (over the freezer) travels across the open space where the wiring is, and ends in the pan under the compressor. Now, my unit is from around 1997 and this tube would dip down slightly while crossing this space. The evaporator would send it's water through the tube to be removed by the heat from the compressor. Problem is the 'dip' would hold some water after the cycle ended and the water and heat are an ideal environment to create mold- lots of it. It clogs the tube and causes the evaporator tray to overflow into the freezer. I originally fixed it by making a tiny hole in the tube and using a basketball pump to blow the crud through. But, today, I've given up and cut 1" out of the middle of the hose and before inserting a double ended 1/2" plastic nipple (union) I used a tubular brush to push the crud out in both directions. It takes a while to accumulate to the point that water doesn't move; then I'll disconnect and repeat.
Posted on May 27, 2009
We have had the same problem for years and had multiple repair attempts at solving the problem. The simple solution was supposedly the condensation drain line was blocked, water would then accumulate on the drain pan above the freezer, and then drip down and freeze like Niagra Falls in the winter. But that solution worked only so long before it happened again. Then Sears came and replaced some heating element. That last about 9 months and it happened again. Now we are told that this is a "defective GE model" that requires an "upgrade" kit that is over $600. Basically, GE acknowledged finally the model is a piece of junk that they designed wrong, and now long after the warranty expired, we have to pay for it. We are never buying even a GE light bulb again. Good luck with yours.
Posted on Aug 26, 2008
    Problem Solver:
  • 14 Answers
I'm currently having the same problem and was told it was the defrost heater by more than one source. So I began the process of getting to it when I dicovered there is a pan heater. If it ia not working when the defrost cycle runs the water ends up in the pan and freezes until theres no more room then it runs over and you have ice sicales hanging from then shelves all the way down the freezer. I hope this helps.
Posted on Mar 31, 2009
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
Tip
What to check when your refrig. cools ok but leaks water from freezer
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
Gene
on Jul 31, 2011 | Refrigerators
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
GENE
Oct 13, 2011 | Refrigerators
Looks like water dripping from frezzer, but there isn't an ice maker hooked up in the freezer. top refridge shelf covered with water and ice
you have a blocked drain.i use a steamer to clear the drain,they cost around 50 bucks,take off the back wall.melt out ice with hair dryer,crack out as much ice that you can with plyers or hammer,gently hit it and it will crack out if the floor is a sheet of ice and a putty knife comes in handy,when you melt out and remove ice stick the tip of steamer in drain and clean the drain out,hit it for 10 seconds then stop wait a minute and hit it again,you don't want to damage the drain line it's plastic so take your time,pour hot water down drain to make sure it's clear you might have to use hair dryer and heat up the inside of ceiling in the fridge section in the middle of back wall and ceiling where the drain is, the air ducts are there also,whenwater stops dripping you'll know you melted all the ice,good luck
Jan 23, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice make not making ice, water dripping in Freezer
need to replace coolant in the freezer. Either that or electricity cuts out. check cable
Aug 24, 2009 | GE Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
687 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
