Question about Sony Playstation 3 (PS3) Console
Tried to hook up ps3 to a different, older tv. was hooked up with hdmi cable and optical audio cable. bought a component cable that works with the ps3. I can't get a picture or sound. or anything else. do i have to change the settings in the main menu to something other than hdmi? if so, not sure how to since I can't get the menu to come up
    Scholar:
  • 81 Answers
HDMI is a digital signal, so your TV and your PS3 are basically talking to each other over the connection at all times. That's why when you plug an HDMI connection into your PS3, it can detect the connection and try to switch right to it. Component cables don't work the same way, they only output information, so it's a one way street. Your PS3 is still outputting information, but it still thinks it needs to output to the HDMI port. The fix is pretty simple, and there are two options.
The Long Way
  1. Plug your PS3 into an HDMI TV.
  2. Change the Audio settings first, so your console outputs audio to a Component source.
  3. Now change the Video settings last, so the PS3 is outputting to a Component source as well.
  4. Your screen should go blank once you do this. Hit the X button once, wait a moment, then use the power button on the front of the PS3 and turn it off.
Now just plug the PS3 into the other old TV with the Component cables, and turn it on. You should have picture and sound now.
The Short Way
  1. Leave the PS3 plugged into the old TV, and turn it off with the front power button. Once the light has turned Red, hold the power button down for at least 5 seconds. Don't let go until you should hear the system beep twice.
Now you should be able to use your PS3 on the older TV without a problem.
The Short Way is a simple reset of your video card, it causes the PS3 to revert to outputting to it's out-of-box settings. If neither of these ways worked, check here at the Sony website, and one of those solutions may better fit you, but it sounds like one of the two solutions above should solve it.
Please leave a comment or rating letting me know if this solved your problem, constructive feedback is always welcome. Good luck with your console and good luck with your games.
Posted on Dec 29, 2010
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
229 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
