Question about Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer
My positioner arrow shows a question mark blinking in top and doesn"tshow my position, I all ready change the anntena and the problem persist
  • 36 Answers
The blinking indicates a satelite not finding you. push the done button for that location and the Garmin should reset itself. don't start the garmin inside any garage.
kdog
Posted on Dec 29, 2010
I have a Insignia NSL37Q10A, when you turn it on it display's
Change input device to some other like a DVD player. Look for loose contacts in RC jack, cable, sockets. Look for any jammed buttons on TV or on remote.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 03, 2012 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
Where does the cam position sencer located at
It's officially called a CMP Syncronizer.
There are stern warnings on the page associated with this.
CAMSHAFT POSITION (CMP) SENSOR Removal & Installation
CMP sensor is located on rear of engine, behind intake manifold. Before removing, note position of electrical connector on CMP sensor. Remove upper intake manifold. See UPPER INTAKE MANIFOLD . Disconnect CMP sensor. Remove CMP sensor screws and CMP sensor. To install, reverse removal procedure. Ensure CMP sensor electrical connector is pointing in original direction. Tighten CMP sensor to specification.
2 . Failure to use synchro positioner during installation will cause fuel injection to be out of time and may cause engine damage.
CAUTION: DO NOT rotate crankshaft when Synchro Positioner (T95T-12200-A) is positioned on CMP synchronizer. Armature tab will be damaged and synchronizer timing may be shifted. Removal
1. Position crankshaft to TDC of cylinder No. 1, on compression stroke. Note position of electrical connector on CMP sensor. 2. Disconnect negative battery cable. Unplug harness connector from CMP sensor. Remove CMP sensor screws and CMP sensor from positioner. Remove synchronizer hold-down bolt and CMP synchronizer.
Fig. 2: Exploded View Of CMP Synchronizer Assembly (Typical) Courtesy of FORD MOTOR CO.
CAUTION: DO NOT rotate crankshaft while synchronizer is removed from engine. Installation
1. Install Synchro Positioner (T95T-12200-A) on synchronizer housing. See Fig. 3 . Rotate synchronizer shaft until vane on shaft aligns with slot on synchro positioner. Rotate synchro positioner until engaged into notch in housing. Dip drive gear in engine oil.
Fig. 3: Installing Synchro Positioner On Synchronizer Assembly (Typical) Courtesy of FORD MOTOR CO.
Fig. 4: Positioning Synchronizer For Installation Courtesy of FORD MOTOR CO. 2. Rotate sychronizer assembly so that synchro positioner is 60 degrees counterclockwise of crankshaft centerline before inserting synchronizer assembly into engine. See Fig. 4 . 3. As synchronizer is inserted into engine, synchronizer will rotate. When seated, synchronizer electrical connector should be located in original position.
CAUTION: If CMP sensor electrical connector is not positioned correctly, DO NOT reposition connector by rotating synchronizer. This may cause fuel system to be out of time with the engine, causing possible engine damage or an engine misfire. Remove synchronizer and reinstall. See step 3 . 4. Install hold-down clamp and tighten bolt to specification. See TORQUE SPECIFICATIONS . Install CMP sensor to synchronizer and tighten to specification. Ensure CMP sensor electrical connector is in original position. Reconnect wiring to CMP sensor. Connect negative battery cable.
May 03, 2011 | 1995 Ford Explorer
Can't change name on phone? the screen that pops up reads "terminals&sets" and I "set" to change a certain line. Show set is displayed. I type in the number that the name needs to...
It sounds like your in the right area, you just need to go a little farther into that sets programming.
when you enter in the persons extension number press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Dec 22, 2010 | NorStar M7324 Telephone
How to change crankshaf positioner sensor
Its a pain and takes a lot of patience I got a really long extension i think its like 18" with an 11mm socket and you should be able to get it just right to get the bolt out than go back up top squeeze your arm down behind the engine and wiggle it out there is no easy way to do it unless you want to take all the linkage off the transmission than you might be able to reach it from the bottom just be persistent youll get it its located about 1 o clock position on the bell housing
Dec 18, 2010 | 1995 Jeep Grand Cherokee
My hp printer 960 c ligth keep blinking red
One or both ink cartridge is failed.First remove the cartridges and clean the contacts on the carriage unit using piece of cotton and some alcohol.If problem persist open the cover and look where the carriage unit stops.There is two marks on the left side where the carriage stops.On the carriage there is a yellow arrow.If this arrow show left mark the color cartridge ia failed and need to be replaced.If the arrow show right mark replace the black cartridge.If you replace both cartridges and problem still persist carriage unit or logic board assembly is failed and your printer need service.
Nov 26, 2009 | HP DeskJet 960c InkJet Printer
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
Oct 23, 2009 | NorStar Meridian M7310 Phone
Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer Logo
375 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
