Question about Maytag MSD2434GE Side by Side Refrigerator
Ice Maker The ice maker stopped working it is no longer making Ice I checked the switch th make sure it's on and I know the water line is on because I can still dispense water but the tray isn't filling up anymore is there any other things I can check to see what the problem might be?
The water valve appears to be the problem. The water valve ,located on rear of ref. at bottom has two (2) sides to it. One side feeds the water to the water dispensor and the other side feeds the ice maker..
Posted on Jul 07, 2008
Ice maker makes hollow ice
Not enough water. Check water filter if you have one and replace. Check water inlet valve pull supply line off of water inlet valve and make sure the screen in the water valve is not stopped up. make sure water line is not kinked.
Jul 11, 2014 | Marvel Appliance Ice Maker
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Have a newer GE side by refrigerator the ice make stop working it no longer makes ice.
The normal life span of an ice maker is anywhere from 2 to 5 years. Something to check before replacing yours is 1) make sure your water filter is current, this would cause production of ice but also in the dispenser when trying to get water. 2) Check the fill tube to make sure that there is not any ice formed there preventing the water from getting to the ice maker. 3) Check the temperature in the freezer. Even though things may be frozen, the ice maker requires that it be below 10 degrees F to function. If the temperature is higher than this then you have another problem causing you ice maker not to work.
Jun 01, 2012 | Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Maytag MSD2434GE Side by Side Refrigerator Logo
224 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
