Question about Dell 1707FPT Monitor
I'm not getting any power to my Dell 1707FPT Monitor. Is there any way to fix that?
  • 11,361 Answers
You need to take it apart and look at the solder joints on the 3 legs of the AC input jack, then look for bad caps with leaking/bulging tops as shwon in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Dell%201707FP%20Rev%20A01/
Be real careful on the front bezel switch/flat cable assembly!
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Posted on Dec 30, 2010
1707fpt dell flashes video and green power light
i will give you some tips
1- If the power light goes from green to orange) this is almost always an issue with the computer and not the monitor
2- If the monitor power light turns off, then it is almost definitely a problem with the monitor.
there are some reasons your monitor turning on and off
01-One reason the monitor could shut off is because it is overheating.
02-If the power cord is loose and is not securely connected to the back of the monitor it will cause the monitor to turn off.
03-If the monitor is staying on, but you loose the video signal, it's very likely an issue with the video card or motherboard in the computer. This could also be an issue with the computer or video card overheating or a defect with the video card.
04-Another reason the monitor could shut off is because of a malfunction in the circuitry. There could be a short in the wiring or some other failure in the circuitry, causing the picture to go black or causing the monitor to shut off completely
05 another reason the monitor on and off is because your monitor power supply chipset is damage
hope that it will help you
Feb 15, 2014 | Dell Computers & Internet
Monitor 1707fpt
I would suggest you try this to fix your problem. Go to Control Panel from the start menu if you are using Windows 7 and Windows Vista. Click on the Display Setting and adjust the screen resolution to the recommended Screen resolution. On the Display Setting at the top of the you should see number 1 and 2 with a large box ,on the right side of these boxes there is a menu that you can click on, these menu are {Detect and Identify} click on Detect first and then Identify. I hope this solves your problem.
Jan 05, 2014 | Dell Computers & Internet
Monitor goes from green to yellow ..yellow keeps flashing . does not have any problems to date.i noticed the picture was blinking ...getting smaller then larger then it completely went out ...
Does it do the same hwen attached to another PC? This model is known to have blown capswith domed tops problem.
You can see it here:
Please leave rating if it helps.
Jan 26, 2011 | Dell 1707FPT Monitor
Can this montior work with any pc
Hi there. Yes this monitor should work with any PC so as long as the PC has a the same style of connector. For example if the monitor has a blue plug (VGA) on the backside and you PC has one. It might even have a white plug (DVI) and as long as your PC has the same style of plug your fine.
Best of luck..
Nov 18, 2010 | Dell 1707FPT Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
The power buttom on my Dell E228WFP 22 not working
MY MONITOR JUST WENT OUT AND I GOT 2 RED LINES ON EACH SIDE OF SCREEN SO I UNPLUGGED IT NOW IT WONT POWERUP AND LIGHT IN BUTTON WONT GO ON
Feb 27, 2009 | Dell E228WFP LCD Monitor
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell 1707FPT Monitor Logo
260 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
