Question about Hitachi 50DX20B 50" Rear Projection Television
Im seeing three separate colour outlines on people and objects red,green, blue
    Genius:
  • 1,267 Answers
You have a convergent problem, where the red, blue, green projector lamps are out of synch. See: http://www.youtube.com/watch?v=esk4nYZKFcg for a pictorial on how to fix convergent.
Posted on Dec 29, 2010
My zenith tv model SR2075DT had this continous Red tint. I have tried fixing it through settings and NOTHING works. Someone please help me
It is likey the blue lamp has failed.
They are relatively cheap to replace and you can buy them online.
There are dangerous voltages inside the cabinet.
If you can see the lamps through any of the vents, you may be able to see the lamps. Check to see if blue or green are not working. There should be three separate lamps. Red Blue & Green. This is assuming the colour is like that on all sources.
If it is only on one source, check the component cables in the back of the TV.
Oct 20, 2013 | Televison & Video
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
I have a 60 inch Philips tv and the picture is kind of blury and a little red. What is tha caused from?
THREE possible reasons for this:
I will list each and describe for you:
1.) If redish picture go to a black and white channel; is the screen somewhat red or black and White? This is adjustable from inside the set.
2.) If colors are skewed or look like they have a red outline it may be a convergence problem. See attached photo.
3.) Some of these sets develop a problem with the coolant which is used to keep the face of each of the three tubes cool; it is called Glycol. You would have to remove back cover and with set on look into each of the three lens (red,green,blue) to see if you have a clear red, green and blue picture.
Which best describes your problem?
Aug 10, 2010 | Philips 60PP9352 60" Rear Projection...
Blue shades on left side of the screen
Hello seems like u have a convergence problem if the colour red /blue /green around the outside of people or objects in one of these colours the convergance chip will need replacing but u can also check in your menu to see if this can b ajusted by remote only sometimes .
Apr 11, 2010 | Toshiba 43A10 43" Rear Projection...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Green, red, and blue lights don't line up on screen
hi you have faulty convergance ic also there may be some faulty resistor and capacitors that sit in front of the ic, thanks
shaun
Jun 27, 2017 | Hitachi 50SBX78B 50" Rear Projection...
Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Hitachi 50DX20B 50" Rear Projection Television Logo
195 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
