Question about Sharper Image The IndoorOutdoor Wireless Speaker Speaker System for Most MP3 Players (ECW130)
We purchased the Sharper Image Indoor/Outdoor Wireless Speaker last summer and have only used it twice. Today when we turn it on, it will show the blue power light for two seconds and play the song, and then the light will blink and the song will stop playing with bursts of static noise. We replaced the batteries but that doesn't seem like its the problem. Could there be a shortage?
ginko
  • 19396 Answers
SOURCE: blinking blue lights
Here is the Ionic Breeze GP SI730 Air Purifier service manual:
http://www.fixya.com/support/p94230-sharper_image_ionic_breeze_gp_si730_air/manual-17755
hope it can help you
cheers
Posted on Feb 16, 2008
Bubbabear64
  • 2794 Answers
SOURCE: The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Posted on Sep 22, 2008
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Posted on Oct 11, 2008
SOURCE: Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: Sharper Image Ionic Breeze GP S1719
I just typed in an msg on how I fixed mine. Im an old lady, and figured what the......... cant hurt. so check my msg here somewhere, and start taking out the screws. good luck, in the last couple of hours, ive fixed two of them, just cleaning the contacts. good luck to you.
Posted on Apr 23, 2009
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
Nov 16, 2013 | Panasonic Heating & Cooling
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
My Sharper Image Ionic Breeze, model 51737worked fine but when I turned it on today it wouldn't work. What could the probelm be?
those things are not worth a bit. you should throw it away you could even possibly be causing yourself more indoor air quality problems by running one with the amount of ozone they produce and put into your home. throw it in the garbage.
Sep 12, 2009 | Sharper Image Air Purifiers
I have a 900 MHz Wireless Indoor/Outdoor Mono(Accurian)
yep the power to it is in question and since it is a 9 volt adaptor as mentioned that will need to be checked 9vdc adaptors are over the counter items in most radio shops
Jul 29, 2009 | Audio Players & Recorders
Wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Dec 30, 2008 | Computers & Internet
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
We have the sharper image wireless indoor outdoor speaker and when we plug everything in there is nothing coming out of the speaker. Are we able to get it to pick up satellite radio?
The wireless speakers do not pick up a wireless signal outside of the round wireless broadcaster that came with the speakers. You will need to connect that to your satellie radio to broadcast to the wireless speakers. Make sure the wireless broadcaster component is plugged into the sound source you want to make wireless. After you've connected the broadcaster to the sound source and turned everything on then push the Auto tune button to connect to the broadcaster and recieve the sound.
Nov 27, 2008 | Audio Players & Recorders
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Sharper Image The  IndoorOutdoor Wireless Speaker Speaker System for Most MP3 Players (ECW130) Logo
80 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
