Fills up with water and then does nothing but beep. lights 1 and 7 are on. Have checked under machine and all spinning things that should be spinning are spinning. Have check for burnt out diodes or such and nothing found. Will empty no problem but then wont click on to next stage. Will fill Ok but again will not move on.
  • fwbfred Dec 30, 2010
    Thanks Daniel for quick reply but this model doesn't seem to have a timer as such (it is a Fisher and Pakell MW 511 Pride) It seems to want to spin but just does a wurling sound then a very short jolt and then repeats itself for a few times then shuts down leaving lights 1 and 7 on and of course it will fill and empty when it should.
    regards Fred
    Hi Rick
    The model is a Fisher Pakell MW 511 Pride top loader
  • Washing Mach... Master
  • 17,130 Answers
Possible that the main program controller board is faulty. To confirm that the board is working after choosing the program and setting to start the inlet valve should open as the water flows into the washer. Now One the water stops the motor must engage, make sure the door switch is working. If there is no voltage to the motor then it can be the board. If not the motor capacitor must be checked as it can be low in value or leaked.
Wishing you a happy New Year.
Posted on Dec 31, 2010
  • 1,998 Answers
What is the make and model number of the machine? also is the machine a front or a top load washer? I await your reply thanks again
Rick
Posted on Dec 30, 2010
  • Rick Ead
    Rick Ead Dec 31, 2010
    hello ok firstly take a look at someone else who had almost the same problem and they ended up having to replace the control board but there lights were 3 and 4 and yours are 1 and 7 http://applianceguru.com/forum2/1571.htm... the lights are actually error codes the first thing we need to do is figure out what the 1 and 7 stand for ok found what the error is says the motor controller has found in the pattern recieved from the rotor postioning sensor. Likely causes of this fault are a bad connection on the harness between the rotor postioning sensor and the motor controller, or a faulty rotor postioning sensor basicly means pain in the but basicly the wire that comes from the control board that goes to the rps sensor which is a small sensor that regulates the motor to spin most of the time it is the sensor that goes and be forwarned this is a very involved repair if you are not handy with exact positioning of electrical parts please call a technician if there are any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped if you would like also you can look up the error on this link like i did Thanks again
    Rick
  • Rick Ead
    Message me back if you have any further questions Thanks again
    Rick
  • 4,323 Answers
Hi
If the beep sound is from the dial not from the bottom where the motor is so the issue seems to be with the Timer going bad and should be replaced to solve this issue. However, you can unplug the unit and then blow some air with the help of hair dryer before replacing the Timer motor. If the sound comes from the motor area then it is the motor that should be replaced. When the motor goes bad it will fill with water and empty. One more thing to check will be the door lock-switch assembly, because if the control detects door not locked it won't run cycle and will just drain the water out. Hope this helps...
Daniel
Posted on Dec 29, 2010
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    If it does not have a timer then check the electronic control board
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Machine fills and starts to agitate, then stops. Will pump out & spin but not agitate. Refills with way too much water. Continous 1 second beeps. All lights on or 2nd, 3rd & 4th from left. Not...
Hi just read your posting.Could you please confirm the lights that are on when the machine is beeping as the lights you described that are on is not an error code.Also please confirm the model number for me.It is on s sticker at the back of the machine top left.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Washing Machines
Spin cycles doesn't work, tub full of water
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
