Furance will kick on when theromast set on auto, must set in manul
  • Barrett Palumbo
    Barrett Palumbo Dec 29, 2010
    please tell us in detail what your problem is
    Problem Solver:
  • 9 Answers
REPLACE THERMOSTAT
Posted on Dec 29, 2010
When furance kicks onafter a while the furnace stops working the range hood and the refigerater. after a while its starts working again.
It is difficult trying to understand what you are trying to convey to me. If you live in an older house, this may be the problem. Your furance, refigerator and range hood may all be on the same circuit. Your furance should have a dedicated circuit, nothing else on it. The refigerator should be on a dedicated circuit also, the range hood can be on a circuit with other devices. To find out what is on a curcuit, go to the panel and find the circuit that powers the fridge, have someone watch to see when the light goes off in the fridge, that will be the fridge circuit. Now check and see if anything else is off, eg. if the range hood doesn't work, then it is on the same circuit. If the furance fan will not operate then it is also on the same circuit. Do the same thing with the furance circuit, turn if off at the panel and see what else does not work.
Remember, the furance and the refigerator need to each have their own dedicated circuit.
Feb 21, 2015 | 2002 Bounder 39r
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
I have a 1995 chevy blazer it keeps vapor locking it turns over and won't start I have to let it sit a good 1/2 hr then it will start and go again the fuel pump was changed last year could it be...
Hello! Most common cause is a defective Evaporator Purge Solenoid...Located behind the right front wheel...Two wire connector; Dark Green/White and Pink...Average cost at your local auto parts store is $25...
May 27, 2010 | Jl Audio Stealthbox Single 10" Chevy...
I have a magic chef ultra 97 furnace. the blower started making a noise. i removed the blower and blowed the blower out with air and lubed the back bearing with pb blaster. reinstalled blower. the blower...
u may have a bad ignitor or u might not have hooked up a safety switch or u may have accidentally caused a sensor to go out not knowing but it sounds like the ignitor is bad is it a glow plug or does it spark to light
Feb 26, 2010 | Heating & Cooling
FAN MOTOR CONTINUES RUNNING AFTER HEATING CYCLE IS COMPLETED BLOW
Check the thermostat. Make sure it is set for AUTO fan not ON fan. If that is OK replace the fan relay.
Apr 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Problems with Furnace
On is just the blower fan nothing else, check to see if there is a reset button in the tstat or tripped over load inside the furnace, inside the furance is some safetys, you will see wires runing from each other and finaly to the gas valve, push each untill one of them clicks,then your furnace should start back working, but I would still have someone come out and check why it tripped, because as I said it is a safety, and when it tripps it is for a reason.
Oct 19, 2008 | Heating & Cooling
Furance won't lite
The first thing i would do is turn thermostat down and turn power off wait for a few minutes then turn power back on and then thermostat back up. If it has a ignition module then there should be a blower motor. It should come on then a pressure switch that should click then the ignitor should glow or spark. there should be a round glass circle that you can look through to see the ignitor
Apr 04, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
