Question about DeLonghi EW0507 Oil Filled Radiator Heater
My DeLonghi EW0507 oil heater will not turn on. Is there a safety or reset switch?
  • 45 Answers
SOURCE: how do I reset ?
It should come on automatically, if it does not then the thermal switch is faulty, and has to be replaced.
Posted on Jan 27, 2008
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
SOURCE: I need to reset my Delonghi radiator. it overheated
same problem. any solutions?
Posted on Jan 03, 2010
  • 736 Answers
SOURCE: DeLonghi oil heater model HMW2400TG
one of three things are common causes of this problem ...most likely, dust builds up enough to block air flow then the unit will overheat inside .. that will trip a thermal breaker .. the breaker will reset when the unit cools .. if that problem continues then it may trip a permanent breaker .. if that happens the unit will stop working .. take the unit outside and blow the dust out of it with air pressure.. .. another common problem is if the fan bearings start to freeze then the fan wont run fast enough to maintain proper air flow .. lubricate the fan front and back bearings with light machine oil or sewing machine oil .. don't use WD40 or oil containing teflon .. the lube life is about 5 years so yours is way overdue for oiling the bearings if you haven't done so yet.. a third problem that is common is the electrical connections inside the heater are made with crimped on rivets .. the rivets loosen sometimes with age and a hot spot is created at the loose connection (you might even see sparks there) .. that can also trip the thermal breaker and is generally not repairable at reasonable cost ...
Posted on Aug 15, 2010
rockmeister
  • 2047 Answers
SOURCE: HOW DO I WIRE A REPLACED SWITCH FOR A DELONGHI 14
Usually this would depend on which of the switches you are looking to replace. Are you refering to a switch on the unit or one where the unit is plugged to? please clarify which of the switches you are refering to. Hoping to hear from you soon.
Posted on Jun 22, 2011
My Delonghi heater won't heat all the lights work modelEW7507EBL
Heating element might gone.check the volts on both ends of the element with the multimeter if you can be careful do not touch any part coz high volts could be dangerous, so don't do if you do not have enough knowledge.
Nov 04, 2015 | DeLonghi EW0507 Oil Filled Radiator Heater
How do you use the dial and what is it for
This heater has both a dial and a wattage selector. The dial is a thermostat, so it will turn the heater on and off as the temperature gets warmer and colder. Just like the thermostat on the wall in a house. The wattage selector switches let you pick how much heat goes in when the thermostat (the dial) tells the heater to turn on.
If you set the wattage at a higher level, the heater will use more power at once, but will turn on and off fewer times to keep the temperature determined by the dial setting.
If you set the wattage to a lower level, the heater will use less power at once, but will turn on more often and still use about the same amount of electricity.
So the dial really lets you pick how warm you want it to be in the room, and the wattage switches let you pick how often it turns on and gets hot. So this dial really determines how hot your room will be.
Feb 11, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
Family member knocked heater over.Now it makes noise like water dropping into a pan of oil. I can hear what sounds like water dripping in the heater, Help
Don't get too excited... it will stop after everything settles in there again...
It is just the oil dripping back down inside...they are not toally full with oil...
heatman101
Jan 23, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
Do i need to add oil
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Jan 12, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
My heater turns on but then turns itself off.
It is possibly a safety sensior that turns off unit when tipped over. Try turning unit over to c if it will reset, U may have to do this more then once.Usually this will do the trick,
Jan 01, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
Why does the coird get hot? Thanks
The cord gets hot because of the load on the unit... thses heaters pull alot of electric and the electricity going through the cord makes heat... make sure that you have it plugged directly into the outlet and do not use and extension cord... that will make it worse...
some heating of the cord is very normal...
heatman101
Aug 07, 2010 | DeLonghi EW0507 Oil Filled Radiator Heater
Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Feb 13, 2008 | DeLonghi EW0507 Oil Filled Radiator Heater
Burnt plug
I will check, meanwhile go to the hardware store and get a replacement plug for it. the cord has a ribbed conductor and a smooth conductor. the ribbed conductor goes on the brass screw on the replacement plug. the smooth one goes on the other.
Aug 27, 2007 | DeLonghi EW0507 Oil Filled Radiator Heater
Open Questions:
See all DeLonghi EW0507 Oil Filled Radiator Heater Questions
DeLonghi EW0507 Oil Filled Radiator Heater Logo
144 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
