Question about LG WM2077CW Laundry XL Front Load Stackable Washer
@ questions I have called around. Many service people have told me that the parts are hard to get, expensive. Some people do not want to service this product. Please tell me your thoughts on this. Thank you.
  • 489 Answers
Check the LG website for an authorized repair center in your zip code.  Then call that company and ask the same questions.
Posted on Jul 23, 2008
My freezer isn't freezing anymore.... it keeps things cool like in the refrigerator part but that's about it. Maytag model MTB2156GE. I've been told several different possibilities. Replaced the...
freezers need good door seals to work. The fact that the freezer is keeping things cool indicate that it is working but the cold air is getting out ,probably at the bottom of the door
one method of checking door seals is to inspect for cracks,hardness
use a piece of tissue paper and place under seal at door opening and try to pull the paper out. if it comes easily then the seal needs replacing
Mar 22, 2015 | Refrigerators
My engine on my 1999 chrysler sebring 2.5l is making a ticking sound or so. I was told that might need to be replace. I just want to know more about this. Is this hard job to do and expensive? What is a...
It is most likely your lifters need to be adjusted. It is part of scheduled maintenance. I think at around 100,000 miles or so. It will probably cost a couple hundred dollars.
Sep 17, 2011 | 1999 Chrysler Sebring
RTG-74XN2 won't put out hot water until about 9am.
Tankless questions are complicated because these units have many parts, and both internal and external issues can cause problems. Also problems can arise from combination of issues including maintenance, incoming water temperature, pressure, air quality, venting, water quality, water pressure, in addition to internal washers, gaskets, and parts functioning perfectly with each other over time.
Hot water only after a certain time of day indicates problem might be pressure related.
Which could be local water supply, or clog in line, or sediment on pressure sensor, failed pressure sensor, dirty in-line sediment filter, improper vent, or combination of things listed.
Rheem suggests calling service technician.
Service technicians train for years on one brand of tankless, and then see something new each day.
To understand why service technician is recommended, view number of UNanswered questions on following link showing one Rheem tankless model number.
http://www.fixya.com/tags/rtg_74pvn
I suggest avoiding tankless water heaters since all costs are energy.
Clogged pressure sensor after 2 years exposure to hard water. De-liming tankless will not prevent failure from hard water.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
I have a 2005 yamaha r1 .. some times when im down shifting I half to keep trying to down shift to get it to go into a gear mainly 1st sometimes other gears but not so much and same thing with up shifting...
Hi, Tom you may need a clutch adjustment for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Gear shifting problem
Hard shift into first
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Dec 31, 2010 | 2005 Yamaha YZF-R1
I have a Sharp xr10x, I had one before, on the older one the color wheel went out and the repair shop said it would cost $700 to repair it so I bought the current one on e-bay for about $200.00 since it...
whatever service shop told you $700 was out to hose you. there's no way with parts and labor it should be over $300. so to answer your questions: yes, sharp calls it a filter, but only on some models. on the xr-10x, it's a c/w assy (PFiLWA087WJZZ). to extend the life of a colorwheel, and any other part of a projector, keep it cool, clean, and free of dust. dust holds in the heat that the projector is trying to expel. blow out dust with canned air. and you are going to need a colorwheel. you can have them replaced for $300 each, or buy the colorwheels and replace them yourselves. either way, you're going to want an authorized sharp service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 21, 2009 | Sharp XR11XC-R Multimedia Projector
I need to know where the fuel filter of a nissan altima 2003 is located
The fuel filter in a 2002 Nissan Altima is located in the fuel tank and is a non-serviceable item. That is what the dealer told me. You can always call up the dealer and ask them where something is located, after all you paid thousands of dollars and bought a warrenty so don't be shy about calling them up and asking them questions. However dealers can be expensive, so shop around for the best price or find a friend who can help and save yourself a bunch of money.
Jun 11, 2009 | 2003 Nissan Altima
My Lexmark C510 keeps saying paper jam and has hardly grabbed the paper out of the paper tray. Also says "short paper". I called Lexmark who told me that I needed two parts: a paper feed roller (56P1655)...
If service were required, Lexmark would have offered to place the service call for you.
Go ahead and order the parts, if they look to complicated to install, then you can place a service. Most "C" level color lasers require on-site service and should not be taken to a dealer.
Don
Jun 03, 2009 | Lexmark C510 Laser Printer
Thanks!
To me it really depends on how many copies the unit has. If you are over 200K it may be time to upgrade, only because parts are expensive after that point. I have always liked Canon copiers, because you don't have to mix developer, it is already blended with the toner.
Jun 13, 2008 | Sharp SF 2020 Copier
Repair front load washer
We've had that same problem since we bought ours 3 years ago...but it was intermittent, and we never knew when we'd get the spin-dry cycle to work. Sears made 10 service calls, and replaced everything in the machine except the motor and motor control board. Those two parts were ordered and delivered as a result of the 10th service call. Of course, when the service guy was here, the spin worked! After he left, the next load did not spin. Frustrated, I opened the front end and looked around. I had noticed how violently the drum shook while operating when the service guy was here, so I decided to see if the wiring harness from the motor might be loose where it plugs into another harness that must go to the motor control board. There was a definite tightening of that connection as I squeezed the two harness plugs together. (I tightly secured a plastic zip-tie around that connection to prevent it from vibrating loose again) Since then, I have had absolutely no problem with the washer. I called Sears and told them I had managed to solve this long-standing problem on my own, and how, and also told them to cancel the service call to install those parts I ordered, but to pick them up and reimburse me for them. (I never opened the two boxes that arrived) They did just that, and we finally have a washing machine we can rely upon to complete the wash like it's supposed to. It's been a very frustrating and expensive 3 years, but now all is well.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
