My fisher and paykel awf60md front loader washing machine doesn't spin properly
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
Hi I have a fisher Paykel washer front loader wash smart, it has err 37 flashing and doesn't seem to spin or drain water
I no some of them have a filter at the front right down the bottom just about under it i no this can cause that problem
Aug 28, 2015 | Fisher Washing Machines
How to replace door seal on fisher paykel front loader ?
ill start off by saying this is one of the hardest things you can do on a front loader alot harder than it looks alot of the time you need to remove the entire front half of the washer to get in there properly even then its still difficult with the right tools, if you still wish to attempt this i will need the model number so i can instruct you step by step
Sep 06, 2014 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
711 Lid lock issues
see this causes:
t doesn't pump or spin
frozen puller, or broken belt, lid switch defective or open replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
It spins only with the lid closed
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
If someone uses wrong washing power and puts front loader washing power in a top loader can that do or cause any sort problems
That's no big deal. It won't harm a top load washer. Just try to use the proper stuff next time.
However, you should never use regular top load laundry detergent (non HE) in a front loading machine though, because that can quickly cause problems.
http://www.myefficientplanet.com/tag/too-much-foam-wrong-detergent-front-loader-washing-machine/
Good luck.
Mar 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
At spin cycle pump only runs for 3 seconds then stops
Sounds like the pump motor is overheating. Probably need a new one.
Feb 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
