Question about Sylvania G-Netbook
I bought this lil gadget but i cant connect the the ethernet. it stated that im connect by once i click on the E no connection can someone help me.
  • vero g Dec 30, 2010
    i actually went to a hotspot and i couldn't connect so i try doing this at home even put in the password from my internet connection with no success. At this point i need like a walk through... SO frustrating trying to do this. I though it would be easy.
  • 600 Answers
You are only connected to the router not the internet
If your trying to get on the internet with a wireless connection.and running WINDOWS, .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 29, 2010
  • mrninja
    mrninja Dec 30, 2010
    It should be easy....If you are running LINUX.. forget it -many problems with drivers, etc, try the troubleshooting flow chart again at http://www.daileyint.com/hmdpc/laptop/wi...
I have tried to connect to xbox live
you need to make sure you have enabled ICS, Internet Connection Sharing. To do so, you go in to the internet settings (found in the network sharing centre)choose your net connection, click 'view status' and then click properties (the first of three buttons at the bottom, properties, disable and diagnose) then once the window pops up, there is a sharing tab, check the box that states 'allow other users to connect to this computers internet connection' after that simply dis connect and re connect and the new settings will be able to be used once you do a xbox live network test. Good Luck.
Nov 04, 2009 | Microsoft Xbox 360 Console
Im a new compaq presario cq60 owner- im trying to setup wireless network at home-att.is my only option in my area- have a 2wire 2701hg-b wireless router and cant get it to work internet,wireless only with...
You will need to check the wireless settings of the router.
You said that it works only with the ethernet connection but not with the wireless connection.
Check the IP address of the computer when it is connected with the cable to the router. note down the default gateway number.
Open the set up interface of your router with the Default gateway number.
once you are able to open the set up interface of your router, you will be able to change the wireless settings of the router.
after that you will need to conncet to the wireless network on your laptop.
Click Here for more Information
Oct 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Bad connection to ps3
once you have the mobile conection pluged into your ps3 try scanning 4 networks if it finds ur network click onto it and type in the WPA key that came wit your mobile conection
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR CONECTION TANKS.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Usb broadband modem
Im not aware of any gadgets, but you can always use the USB stick on one laptop, share the internet connection, and connect the other laptop throught the shared connection.
That would require your laptops to be networked, either by a crossed cat cable or with regular switching or routing.
Feb 02, 2009 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Wireless router
device manager and if you see ethernet right click and disable
don't disable the wireless network then right click the wireless and if you see enable click otherwise click and update
restart--- then control panel and network connections
then view available networks if a network shows highlight and then click connect
if there are no networks then on left side of page click refresh network list do this until you see a network then again high light and connect
please let me know if you are connected now
Feb 01, 2009 | Acer Aspire One PC Notebook
Cant connect to the internet
680 Error is No Dial Tone, Make sure you are trying to connect with a Ethernet port, DSL will need a Modem, In between the computer and Phone jack (Sorry if im being too basic, but i want to make sure we cover EVERYTHING) Go in to the connections and try using the Ethernet adapter. Let me know where that gets ya
Nov 24, 2008 | Compaq Armada E500 Notebook
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Cant connect wireless router to laptop
With cable attached type http://10.0.0.2 and enter the username admin and the password zoomadsl then go to basic setup and make sure your ISP username and password are listed under PPP then click start next to 'configure my network' save changes and write to flash. Make sure the DSL light is on solid (otherwise its an issue with your phone line/isp account).
Jun 24, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Plugged ethernet cable innto laptop from cable modem and nothing
Click Start / Control Panel / Network Connections.
Your Ethernet status should show under LAN or High Speed Internet. It might be disabled, in which case, right click & ENABLE.
Let me know how you get on.
Jan 10, 2008 | Dell Latitude C640 Notebook
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
