Question about Sony BDP-S300 Blu-Ray Disc Player
Brand new sony bx57 having intermittent audio problems. once in awhile a white line will go down the screen and then sound willl cut out until i power player on and off. happening with Blu ray discs, not dvds.
  • Sony Master
  • 6,771 Answers
This is clearly manufacture defect, the laser pickup assembly is the problem, I would take it back to the dealer for exchange.
Posted on Dec 29, 2010
Intermittent cooling issues
Sounds like you may have a relay problem, they will cut the compressor off and on until they just go bad all together. Do you here a clicking sound down by the compressor in the back every once in awhile?
Jul 31, 2015 | Refrigerators
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Sony bdp-bx57 signal cuts out
test the connection see the diagram attached. Clean the contacts and connector with contacts cleaner.180f246a-cc1f-493b-9d8e-3abff472975f.jpega07d2d96-4cdd-4858-8bc3-356bb92dae0b.gif
However you can restore in the menu to factory default.and see what happen.
Jul 13, 2013 | Sony BDP-BX57 Blu-Ray Player
BRAND NEW JVC GZ-MG330AU Blank White Screen W/ Blue lines
If it is brand new and came with a warranty, return it. I hope the symptoms are continuous(not intermittent).
Jun 16, 2009 | JVC GZ-MG330 HDD Camcorder
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
Soundcard problems
I'd say to look at latency settings and sample rates. also disable screen savers and power management.
Jul 09, 2007 | M-Audio Delta 66 Sound Card
Sony BDP-S300 Blu-Ray Disc Player Logo
107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
