Question about KitchenAid Kitchen Ranges
I have a KitchenAid Selectra range Model number ykeri501aw0. The display panel reads F2. The commands and the oven does not work. The stove top works. The fuses have been checked. Help!
fridgetech
  • 473 Answers
SOURCE: F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Posted on Nov 07, 2007
Cyril J
  • 45 Answers
SOURCE: Kitchenaid Selectra Range Fuse location?
unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
Posted on May 16, 2008
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
SOURCE: Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Posted on Apr 09, 2010
SOURCE: Error message EO-F2 on Kenmore range/oven
model790.9503 gives f31 code
Posted on Jun 24, 2010
Schott Ceran. Why doesn't oven work?
Might try heating element in stove
Oct 03, 2015 | KitchenAid Kitchen Ranges
Hi, I have a Selectra 30 and the panel has gone dark and the oven door is locked. If I unplug it and remove the back cover I can unlock the door manually. When I plug it back in the door locks again and...
First of all, why did you post a question about an oven under a dishwasher question? What is a Selectra 30? That is not the model number. The model number of the dishwasher in the subject does not help. Without knowing anything else, I would say you have a bad control board.
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
Display reads EO -F2- stove top works, oven will not
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
CONTROL PANEL WON'T WORK AND HAS - F2 E0 - ERROR
Remove the power and disconnect all connectors to the control board and put them back on one at a time. If it still won't work the board may be faulty.
Aug 26, 2009 | KitchenAid KESC300 Electric Kitchen Range
May 16, 2008 | Kitchen Ranges
Open Questions:
Kitchen Ranges Logo
57 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
