Question about LG Refrigerators
How do I remove the plastic light cover on a LG Refridge Model GR-P197NIS? I have tried but can not find a release button anywhere and am scared I may damage the cover?
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
SOURCE: lg GR P197NIS ice maker
how to replace lamp for GR P197NIS
Posted on Jun 03, 2011
LG REFRIGERATOR-FREEZER MODEL GR-B207WLQ HOW TO CHANGE LIGHT BULB IN REFRIGERATOR
Just remove the panel of the light bulb present in the
REFRIGERATOR and simply remove the bulb.
May 06, 2017 | LG Refrigerators
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
Anyone know how to remove the plastic dome light cover? It's the light in the center of the roof over the back of the front seats, and it is made of plastic. I tried to remove it, but if felt like the...
Use a flat-bladed tool on bezel to release tabs and gently pull down to remove the roof console. Disconnect the electrical connectors. The procedure is the same regardless of which assembly (garage door opener buttons, panoramic sunroof, etc.) you have.
Apr 24, 2014 | 2008 Saturn Aura
Lg GR P197NIS ice maker fridge not work problem
Jan 19, 2011 | Refrigerators
Lights stay on inside Sears - LG fridge. What is solution?
sounds like the magnet that detects the door closed has failed
Apr 20, 2010 | LG LRFD25850 French Door Refrigerator
Kelly
Apr 09, 2010 | Refrigerators
Riso GR 1700 OK light will not come back on ,nor will it release
switch on the machine and press the astrex button left of the zero button. The code that comes on the display would be helpful. or you you could shoot in the dark and reset the machine by switching off holding down the 2 top right side buttons and switching on the machine. Then release the buttons and off and on with machine.
Mar 25, 2009 | Riso RZ220 Duplicator
Need Part
The Battery Release Button is only supplied as part of the rear unit. Please see below to purchase this item.
Rear Cover Unit for GR-D295U
Mar 14, 2008 | JVC GR-D295U Mini DV Digital Camcorder
Refrigerators Logo
64 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
