Question about All-Pro SPC-85 Utility Heater
Burner will not stay on - All-Pro SPC-85 Utility Heater
  • 1,476 Answers
Asimfq,
The most likely area for your problem is the thermocouple or relay. All -Pro and Reddy Heat are made by the same company Desa. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should explain the problem, how to solve it and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
Why burner on light on stove wont come off
After stove is turned off, the light stays on if burner still warm. If the burner never came on, then it needs to be replaced with new one.
Apr 26, 2014 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Burner light stays on when burner is turned off
Each burner has a sensor in it. These sensors will STICK and stay on even if the burner is off. Usually occurs with the burner that is used the most such as for chicken frying and such. If the burner eye is not the problem then the switch that controls the burner would be the next thing to check. An interesting video that show switch failures:
Jan 11, 2013 | Kitchen Ranges
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Burner light stays on even if burner is off and stays cool
you have the ground wire for that burner on the wrong pin your loosing ground somewhere
so the sensor is reading hot
Sep 26, 2009 | Kitchen Ranges
Red light stays on indicating burner is on when burner is not on.
It should stay on after the burner has been turned off and remain on until the top has completely cooled down,if it stays on and never goes off, the thermostat for one or more burners is faulty and will need replaced.
Jul 26, 2009 | Frigidaire FEF366 Electric Kitchen Range
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Burner ignites but doesn't stay lit
The Thermocoupler is faulty or has a bad connection - once the burner is lit, it heats the thermocoupler which then send a small signal to the valve to stay on - at that time you release the knob and the valve stays on ( supplies gas). If you give me a model number, i can get you a part number and price.
Jan 23, 2008 | Miele 23 in. KM360G Gas Cooktop
All-Pro SPC-85 Utility Heater Logo
80 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
