Question about Soyo Computers & Internet
Have a soyo k7vta mobo w/650 mhz cpu and 1.5 gig memory running XP Professional. seems to run ok when it is not presenting with a problem. Problem is: it keeps freezing up. This board has always done this no matter what operating system I use on it. I have tried registry fixers, Fix-it utilities, etc. Nothing seems to help. Device manager shows no conflicts; drivers are all up to date. anybody have any ideas?
  • wayeblack Jan 01, 2011
    Suggested fix: CPU overheating
    Additional info. Motherboard has hardware monitoring onboard. CPU temp is always monitored and if the CPU overheats Bios will shut the whole thing down. Also the motherboard is capable of handling a CPU running at 1250 mhz, max CPU by multiplier, so it shouldn't be stressed at all. Additionally, I installed a CPU fan capable of handling a 1400 mhz CPU. If the CPU fan does not work correctly, the bios will shut the whole thing down. CPU fan is also monitored by the bios as well as the system fan. CPU fan is currently running @ 5000rpm. Any interruption of the CPU fan at all will result in an immediate shutdown of the system. I have done this accidentally and can verify that it works. CPU temp is currently 98 F. System temp is 80 F. No, it has never shut down spontaneously(other than the aforementioned incident) or refused a restart for temp reasons or any other reason that I am aware of. I also considered voltage fluctuations as a possibility as in the case of a power supply about to go under. Voltages are as follows:
    Vcore=1.68V
    2.5VSource+2.52V
    3.3VSource=3.41V
    5VSource=4.90V
    12VSource=12.06V
    All voltages are holding steady. Additionally I considered Ram to be a possibility because it had 256M memory installed. System monitoring showed 400M in start-up programs consisting of AVG antivirus, antimalware, and ERROR-FIX Diagnostic Programs for system and Reg. I installed 1.5M Ram. No Change. It has frozen up at least twice today. What else am I missing?
  • Kenneth Edwards
    Kenneth Edwards Nov 02, 2012
    I have recently heard about "capacitor plague" and checked several old computers including one with this MOBO that died with such symptoms preceding their death. Sure enough, several capacitors were bulging. The solution is to desolder the defective capacitors and replace them. The defective capacitors responsible for "capacitor plague" use an electrolyte gel. It would probably be a good idea to replace them with solid state type capacitors. If you don't have the patience or the skill to solder and you don't want to pay a lot for someone else to fix it, then consider hiring an electronics student from your nearest community college. They'll sometimes do the work just for the experience/reference.
    Guru:
  • 767 Answers
Have you tried another CPU on the board. It might just be a matter of overheating. Has it ever suddenly switched itself off and not been able to turn back on for like 5 minutes?
Posted on Dec 29, 2010
I have a SOYO SY-K7VTA-B, whats the max ram I can install & what speed
Go to www.crucial.com and run their system scanner. I will tell you the max RAM, the current RAM, the available slots, and what type of RAM will work in your system.
Feb 15, 2010 | Soyo SY-K7VTA-B Motherboard
What dual core CPU is compatable with the dragon plus?
hello sir, hi im afraid that the dragon plus has no AMD x2 (DUAL CORE) compatible CPU. if you want a dual core motherboard compatible, get the socket AM2 version for AMD or the LGA 775 for intel processor.
Nov 06, 2009 | Soyo KT333 Dragon Plus Motherboard
SY-P4I865PE + Dragon 2 v1.0 locks up while running XP with 3.0E P4
I would say ram. Most the time you have lockups is because of a bad ram address. The system will run for a while till you fill up enough resources to reach the bad ram address then the system will lock up. The funny part of your problem is that it doesn't happen with the other CPU. But I don't think the DDR400 ram was designed to be used in systems with a Prescott CPU. The motherboard may accept the ram and the CPU's all right but the Prescott was a pretty powerful CPU for it's time and I think most of the systems it was designed to run in used a lot faster ram.
Jun 01, 2009 | Soyo SY-P4I865PE Plus DRAGON 2 v1.0...
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Problem running ship simulator 2008
I just purchased this same mobo with a 2400+ AMD XP CPU and it's quite fast for my Rail Simulator game. I have a 2800+ cpu that I will be trying soon. Good reference on this is at link: http://www.cpu-upgrade.com/mb-MSI/KT3V_KT4V_(MS-6712).html . there you can find the max CPU that will work with your mobo. Good luck! -
Nov 22, 2008 | MSI KT4V (MS-6712) Motherboard
Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
HI embreelynn,
just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
hope this helps, regards.
Jul 12, 2008 | Toshiba Computers & Internet
EliteGroup K7S5A (does not say pro on the board)
According to their website, the board can take:
AMD Athlon XP (Throughbred up to XP2600+)
AMD Athlon (including Thunderbird)
AMD Duron (including Morgan)
You can then overclock the processor with a BIOS upgrade available at http://www.ocworkbench.com/2002/ecs/k7s5abios/cheepobios.htm.
It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
Jan 13, 2008 | EliteGroup K7S5A Pro Motherboard
Asus P5GD1-FMS 775 Intel 915GExp. need help..
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
Nov 24, 2007 | Computers & Internet
Asus K8N-dl - second processor present but not running...
Hi, Mistyman here. All Asus mother boards that have dual channel RAM slot must have equal ram in each slot. In most cases the paired slots are matched by color for easy ID, some are identified by a printed ID on the mother board. With your board you will have to have run all of your RAM for the one CPU. If you have only one stick this must be in slot one. If you are using two sticks then utilise the dual chanel system that ASUS have and use A1 & A3. To activate the second CPU you will need to install matching sticks of RAM in the B slots. both cpu's will need to have the value of RAM to work together properly. CPU one = slot A for RAM CPU two = Slot B for RAM. Goodluck, the ASUS boards are a value product.
Aug 04, 2007 | ASUS K8N-DL Motherboard
Computers & Internet Logo
51 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Govind Deepak Kumar
Govind Deepak Kumar
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
