Question about Sunbeam Euro Press 4045 Iron
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Posted on Dec 30, 2010
Filter light flashing what do I need to do no manual available
Breville VIN170 Extreme Steam Digital Steam Generator Iron
unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
My oreck cord-free is a JP8100c series. I have had this iron for years and really like it. just recently it will heat for a second or so than the light goes off, I tried holding the reset button and I...
Good news and bad news.
The good news is I found a website with your iron model and the parts, however, the bad news is that the manufacturer decided to discontinue the base the part that heats up your iron. But, if you would like to purchase another one, eBay and Amazon have some great deals. Just in case you want to contact the website I previously mentioned the # is 877-346-4811. Or you can go to ReplacementParts.com. I hope that you find what you're looking for.
Sep 26, 2017 | Oreck Cordless Speed JP8100CA Iron
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
Iron won't heat
thermostat or element. replace.
Mar 26, 2010 | Rowenta Professional DE880 Iron
Iron does not heat light goes on but does not get warm
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Mar 21, 2010 | Krups V70 Iron
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
When i plug in the iron it does not heat up
heating elements is out then have change the parts
Aug 18, 2009 | Rowenta Irons
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
B&D AS 150 is not heating up
It's dead the elements inside are now gone. Spend $150.00 on a Phillips gold based iron. You will be very happy with it
Oct 29, 2007 | Micro Pro 7599 Iron
Sunbeam Euro Press 4045 Iron Logo
1,396 people viewed this question
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
