Question about Electrical Supplies
Can a circuit breaker fail? There is no power in my daughters room, but the circuit breaker seems to be fine. It doesn't reset or fix the problem.
Make sure to click breaker completely over to one side and then click all the way back to reset.
Yes, breakers go bad.
You can check your breaker in a simple way.
Turn main breaker OFF.
Mark daughter's breaker.
Take cover off breaker box.
The main breaker will still have power on the lugs where big wires connect.
Rest of box will have no power.
Notice that each 120 volt breaker has a wire connected to end of breaker.
Use screwdriver and tighten this wire.
If screw is already tight, then loosen screw and pull wire out, and move wire to another breaker marked with same amperage. For example if daughter's breaker is 20, then move wire to another 20. Now there will be two wires connected to that breaker.
Turn power ON and see if daughter's room is restored.
This set up will work fine until you have time to replace breaker with same brand as marked on breaker box, usually available at home center (if available).
If power is not restored by moving wire, then there is a loose wire inside a junction box located in daughter's room.
Test each receptacle in room to confirm that nothing on that circuit has power.
If some receptacles have power, start opening other receptacle boxes looking for loose wire, especially at the quick-connects where wires stab into back of receptacle device.
If whole circuit is off, then to isolate location of loose wire, start at the ceiling box, and see if there is a loose black or white wire. Most electricians run wire from breaker to the ceiling box, and then other wires spread out from there and go box to box until each box has a black and white wire that connects back to original breaker.
Posted on Dec 29, 2010
Trips breaker
tripping breaker indicates over load or dead short
it could be from failed start /run capacitors on the compressor unit ( (most likely)or from vermin across the power board
I suggest that you have a technician inspect and quote on repairs
Jul 18, 2015 | Heating & Cooling
Home electrical
Hi Sammy,
It sounds like there is a direct short on the circuit. Before going any further, check other outlets on this circuit and make sure they do not have anything plugged in that is not expected and does not work. Check OUTSIDE your home, basement, garage, etc. as these locations require GFI protection - and may be fed from the bathroom outlet. After removing devices that are plugged into the circuit, attempt a reset of the breaker once more.
It is not likely that the circuit breaker has failed (but is a possibility). The outlet in the bathroom is probably a GFI type. You can determine this if it has "Test" and "Reset" buttons on it. You should be able to press the Reset button in fully even with power off. After resetting, you can attempt the resetting the circuit breaker as you have described above. If it stays on, try pressing the "Test" button on the outlet. Doing so should trip power to the outlet (and causing the "Reset" button to pop out) but leave the circuit breaker "On". If the breaker also trips, the GFI outlet is suspect and might need to be replaced.
At this point, a qualified electrician should be consulted to locate and clear the wiring fault.
Apr 24, 2013 | Hammering
Circuit breaker is fine but still no power on one bedroom. PG&E said it might be a bad plug/outlet.
Turn off the circuit breaker and locate the plugs that are on that circuit. There is a good chance that the problem is between the closest working and faulty outlet. Starting with what appears to be the last working outlet on the circuit, check that all the wires are secure in all the fixtures and outlets.
If that does not fix the problem, a varmint may have chewed through a wire inside the wall. If you do not have experience with home wiring, you should get an electrician.
Feb 26, 2013 | Electrical Supplies
I have three upstairs bedrooms that are all on the same circuit. My sister tried to plug in something to an outlet in her bedroom and it seems that she jiggled the plug into the outlet and the power went...
I know this may have already been checked, but make sure that any gfci may have not tripped, and also, reset all the breakers if the gfci thing doesn't work... Trust me i know it is annoying but resetting all of the breakers almost always fixes the problem.
Aug 02, 2011 | Electrical Supplies
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Danby DPAC8020 Air Conditioner
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    BenQ 8700 Won't Power On
    As far as the projector goes, the ac power supply is fused with probably no more than a 7 amp fuse, that would blow before your breaker would if the problem were in the projector. The only thing that could case the breaker to trip would be a defective AC outlet socket or your cord for the projector is bad. I have seen cases where cat's have chewed though the cord and shorted it out and triped a breaker, outside of that if the projector is bad now then your thought of sending to the manufacturer is the best one.
    Jun 07, 2009 | Televison & Video
    During heavy lightning, our home temporarily lost power. all power restored except for the master bedroom circuit which would not reset. is this a simple fix or will it require an electrician?
    If this is the only circuit not resetting, and no other section of the home is on this circuit, it is possible that the circuit is defective due to the storm or sometype nof overload on that circuit. However, if you remove the circuit, look at the bus where the breaker was attached and see if it is pitted. Also check if the breaker is fitting securely and not moving. If this does not solve the problem, there is possibly a wire that has come apart, in which case the circuit has to be traced from the panel to the master bedroom.
    You should have power in the room however, as the overhead lighting and the outlet circuit around the wall is usually separated. So there shoulde be some power in the room. If not more than one circuit is out and in which case you may have to enlist an electrician.
    Hope this have helped you with your problem.
    May 17, 2009 | Cutler Hammer Eaton Electical #BD3030...
    3-pole 60 Amp Circuit Breaker is tripped and won't reset.
    When this breaker tripped, it did not go fully to off. Push the breaker all the way off and then all the way to on. It should be fine. If not manually push it to full off once again and then back on. If both attempts fail the breaker will have to be replaced. good luck.
    Jan 25, 2009 | RTO Cutler-hammergd3100 100amp 3pole...
    There is no power to the unit at all circuit breaker not tripped
    blown fuse-easy fix -find book-it is shown behind service panel
    Nov 04, 2008 | GE JVM1651 Microwave Oven
    Electrical Supplies Logo
    1,324 people viewed this question
    Top Electrical Supplies Experts
    ken skalski
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
