Question about Zanussi FJS1225W Front Load Washer
Iz 161 w jet system washing machine
Firstly the quick wash button was really stiff then when i finally managed to get it to work all through the cycle it was bleeping err ! now its not working at all power button is coming on but nothing else is working i ve cleaned the filters , drawer etc , any ideas
I have had a similar problem before, check that the hose outlet is not blocked, or that the drainage pipes are not blocked.
Posted on Jul 10, 2008
Is the alan screw that holds the pully for drum on zanussi iz 12 right hand or left hand tread?
Have a look at the beginning of the tread, and it will become obvious that it is left or right hand.
Jan 24, 2015 | Zanussi Washing Machines
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
Hi I Have a IZ 161 W goes through all cycles until spin starts in slow spin but thats it and the time does'nt move basically it is not spinning to full speed . appreciate any advice regards Sarah
The speed of spinning in the washer depends on the weight of the linen in the machine. if the machine is not fully loaded it will create an inbalance and the motor control unit will sense this and hence spin at a low speed. Solution is to ensure that the machine is fully loaded with enough linen.
Oct 05, 2010 | Zanussi IZ161W Front Load Washer
My Zanussi IZ 161 washing machine has a dreadful smell! I've tried completing a high temp wash and using soda crystals but it keeps on smelling and although it washes the clothes well, if you leave them in...
hi ,well its the wee door down at the bottom right ,open that and loads of water will spill out,it will stink,mop up water and clean out drainage,that should do it,its a simple job and it willl save u pounds,it is just a build up of smeelly water
Jan 09, 2010 | Zanussi IZ161W Front Load Washer
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Zanussi iz 161
Hi there!
Congrats on the twins! Getting any sleep yet?
I think the problem is to do with the water pressure sensor, or hoses inside the machine.
This sensor determines when there is enough water in the machine, and turns the valve off.
If you are competent to have a look, then continue -
Isolate supply and turn off water connections -
Remove the lid by removing screws at the rear, and slide back.
Check the air hoses that are near the drawer area. It is not uncommon for one to just come loose, or rip.
Reassemble and turn on to check opperation.
If this assists you, please spare a moment to rate as Fixya! as I would apreciate it. Thank you.
If not, contact me again for further items to check.
Jun 18, 2008 | Zanussi FJS1225W Front Load Washer
Frigidaire Front Loader
Try checking the filter, it may not be emptying the water quick enough.
Nov 18, 2007 | Frigidaire ATF6000ES Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
113 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
