Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
My delta signature faucet is leaking from the top of the hose. I want to take the hose out to get a replacement. I have started to disassemble the faucet but don't know how to remove the cap.
    Problem Solver:
  • 9 Answers
I am not sure which cap you refer to. there is a cap just below the handle. turn off the water supply for safety and remove handle then turn the cap counter clockwise. to replace the hose you should only have to disconnect at the handle to the sprayer and the other end at the faucet below the sink. if you wish to remove the faucet then after shutting off the water undo the nut below holding the faucet in place. delta have a good web site where you can see a breakdown of this faucet.
Posted on Dec 29, 2010
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
I think our Signature faucet is leaking through the metal pull out coil. It is intermitten. Can a replacement coil be purchased. I'm not sure if this is the real problem though. It is leaking under the...
these are really well designed.take a flashlight and go under and look up.most leaks come from stop valves.if the hose is leaking,you can change o rings.oooooor you might have a bad hose.delta will be happy to replace it. I've found there customer service easy to deal with.
Jan 29, 2011 | Delta Faucet Delta 470-BL-DST Signature...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
517 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
