Question about Canon Pixma iP6600D InkJet Photo Printer
When trying to print a scanned document, paper fed askew from the auto paper feeder, into printer. Printer stopped and paper was removed: printing attempt repeated twice more with the same result. Then another attempt but this time no paper seemed to feed into the printer and the printer cycle completely, stopped and error message appeared.Turning the power off and on has not affected the problem.\r\nThere does not seem to be any paper etc., in the printer pathway What to do?
  • anne4bob Dec 30, 2010
    No, your reply was not helpful
    1) Although I have the error message "Paper jammed in the out slot", there is NO paper or paper pieces to be seen anywhere in the paper pathway..... so I cannot make use of your instructions to clear a paper jam.
    2) Your refer to thePixma iP4200 printer: there is no RESUME / CANCEL button on my printer: Instead there a STOP / RESET button but pressing this has not helped.
    Disconnecting and reconnecting the power has not helped.
    What next?
    Your reply was not helpful because
    1) I have the error message "paper jam in the out slot"
    2) There is NO PAPER to be seen /to be cleared anywhere in the paper print pathway.
    3) You refer to the RESUME / CANCEL button on Canon pixma iP 4200 printer:
    the iP6600D does not have this: but has a STOP / RESET button:pressing this has not helped.
    Disconnecting and reconnecting the power supply has not helped.
    So , what now ?
  • Canon Master
  • 7,733 Answers
Paper Jams in the Paper Output Slot or the Auto Sheet Feeder
Remove the paper according to the following procedure.*
* iP4200 images are used as examples. Other models are similar
(1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remains inside the printer, open the Top Cover and remove it.
Caution: Be careful not to touch the components inside the printer at this time.
After removing all paper, close the Top Cover, turn the printer off and turn it back on.
If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper into the printer, and press the RESUME/CANCEL button on the printer.
If you have turned off the printer in step (1), you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the printer, or if the paper jam error continues after removing the paper, contact a Canon service representative.
top of page
Landscape Credit Card-sized Paper Jams inside the Printer
Remove the paper following the procedure below.
Posted on Dec 29, 2010
  • Doctor PC
    Doctor PC Dec 30, 2010
    top of page
  • Doctor PC
    Select the sheet feeder when paper is loaded in the sheet feeder or select the cassette when paper is loaded in the cassette.
    1. Access the printing preferences by opening the printer properties.
    2. Select 'Paper Feed Switch' as the 'Paper Source'.
      http://usa.canon.com/app/images/service_..." class="h_mi" />
      (1) Paper Source
    3. Press the paper feed switch on the printer to select the paper source in which you loaded the paper.
      Top: When the sheet feeder lamp is lit, paper will be fed from the sheet feeder.
      Bottom: When the cassette lamp is lit, paper will be fed from the cassette.
    4. In Windows, click 'OK' in the Main tab and 'Print' in the Print dialog box.
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
PAPER WILL NOT FEED
hi there !
you may do the steps below:
-Ensure the Paper Tray is Not Overfilled
-Adjust the Printer Paper Guides
-Locate and Remove Any Obstructions Inside the Printer and Input Tray
-Determine if Multiple Sheets Are Fed at Once From the Paper Tray or Automatic Document Feeder (ADF).
-Verify the Print Media Installed Is Compatible With the Printer
-Clean the ADF Paper Feed Roller
-Reseat the Dell Printer Power Adapter
-Try a Different Type of Print Media
*If all else fails
-Replace the Dell Printer
cheers!
Oct 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Printer prints ldocuments but will not print
In Word you create the envelop, specifying the dimensions and the way you will load it (face up or face down). Then you remove the sheets of paper and place a stack of envelops, and adjust the feeder so that the envelops won't drift while they are being fed.
Hope it helps
Aug 30, 2009 | Dell Office Equipment & Supplies
The printer says Paper Jam even there is no paper in it
Please try to clean paper jam area with referring to instruction manual. You printer needs cleaning...
May 04, 2009 | HP Office Equipment & Supplies
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
old marine
old marine
