Question about RCA D52W15 TV
When turn tv on it blows fuse on the power supply board
  • RCA Master
  • 6,771 Answers
It means you have a power supply problem or high voltage issues. RCA sets are well known to take out a number parts when they break down. I suggest a tv tech and an estimate.
Posted on Dec 29, 2010
Testimonial: "thank u very m might have been the issue was not sure thank you "
Power supply is good but TV will not turn on.
Check the main fuse on the power supply board, if its blown replace it and see if it blows again and if it does then you have issues with the hot side of the power supply, it can be repaired if you have some electronic knowledge or you can replace the board
Dec 09, 2017 | Televison & Video
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
DOES NOT TURN ON
Hello
Open your TV and chekc whether the fuse in the power supply board has blown out or not. If it has blown out, never replace it with same type; befor troublshoot the reason for the blown out for the fuse. There must be some reason for the fuse to blow out. Without rectifying it, if you replace it with a new fuse, it may cause more damage to the set.
The power supply board to your TV will look like this.1_10_2012_4_00_19_am.jpg
Jan 09, 2012 | iLO LCT32HA36 Television
Fuses keep blowing in tv
The tv have a short in many parts internally in tv power supply board itself could be anythings on the tv power supply board to causes the fuse to blow over and over again.U will never solved it if u don't have all the measuring elecronics equipments and skills and know how to find out.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 11, 2011 | iLO LCT32HA36 Television
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have a LG 37lc2d and it suddenly turn off and wont come back on, the stand by lights doesnt turn on either. i was wondering if its just the power supply? or how can i troubleshoot this my self to see...
There is a fuse on the power supply close to where the A/C is connected to the board. If the fuse is blown, look at the board and see if there are any burned components and or swollen capacitors. If there are bad components, I would suggest getting a new board.
If the board looks OK, disconnect the connectors from the board but leave in the A/C connector (this way you can isolate the power supply board), replace the fuse, and power up the TV.
If the fuse pops after the power is applied to the unit, then the power supply is bad.
If the fuse is still good, then power off the TV, connect on the main board’s connections, and power up the TV.
If the fuse is still good, then power off the TV, connect the inverters, and power up the TV.
If the fuse blows now, then the inverters and or the panel are bad.
A working power supply will create 5vdc for the main board’s stand by source voltage. This can be found on the power supply at the main board’s connector and it is labeled in black text.
I hope this information helps you.
Good Luck.
May 28, 2010 | LG 37LC2D Television
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Thanks.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
RCA D52W15 TV Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
