I have a usb cable for my printer , it is long but not sure if it is to long ,when i send a job to print it is taking too long and wont print what can i do , i have the epson sx 410 series
  • 4,338 Answers
Most USB cables are 3-6 ft. long. Longer ones tend to attenuate the signal, but that normally happens when the cable is beyond 15" or 5 meters. Did this just start happening? Try un-installing and re-installing the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 29, 2010
Testimonial: "thank you so much for your reply i have since bought a new cable and re-installed the drivers and it works great . thank you very much"
    Genius:
  • 1,739 Answers
The USB cable should preferably be no longer than 10 feet or 2 meters. However if that is not an option you can also check the following to help increase speed of your print jobs.
Printing is too slow
Make sure the paper type selected in the printer driver is appropriate for the type of paper loaded in the printer.
For Windows, clear all customized settings and select Text as the Quality Option from your printer driver's Main window.
For Mac OS X, clear all customized settings and select Automatic as the Mode and move the slider to Speed in the Print Settings dialog box from your printer driver's Print dialog box. See the printer driver online help for details.
Close any unnecessary applications.
If you print continuously for an extended period, the paper may temporarily stop feeding or the print head may pause for a while. This is to slow down the printing speed and prevent the printer mechanism from overheating and being damaged. If this happens, you can continue to print, but we recommend stopping and leaving the printer for about thirty minutes with the power on. (The printer does not recover with the power off.) After you restart, the printer will print at normal speed.
Uninstall the printer driver, then reinstall it. For a new driver for your printer and operating system see here.
If you try all of the methods above and cannot solve the problem, try Increasing the Print Speed (For Windows Only):
You can increase print speed by selecting certain settings in the Speed & Progress window. Click the Speed & Progress button on your printer driver's Maintenance window.
The following dialog box appears.
The table below lists the factors affecting print speed.
Print speed Faster Slower
High Speed Copies On Off
Always spool RAW datatype On Off
Page Rendering Mode On Off
Print as Bitmap On Off
Trust this helps to resolve your problem. Please vote.
Error 49.38.07 printer unable to initialize
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.
Generally this fault occurs when a corrupt file is in the print queue
to clear fault follow these steps precisley
1. disconnect the net cable / usb cable or any other data cable that the machine is connected to
2. cycle the power with no data connections.
3. your machine should now come to ready.
4. take a copy from the platen glass ( straight forward photocopy)
if this prints out then the fault is down to corrupt data.
if at this point the error 49.xx.xx is still present then order a new formatter.
5. before reconnecting the networks -make sure ALL PRINT QUEUEs are cleared before connection otherwise you'll be back at square one
( print queues are on the computers sending print jobs)
before printing your documents its wise to send a test page through to make sure the printer is still able to understand print commands.
hope this helps...if you still need assistance please call Belmonte office equipment on 01614805556
Jan 21, 2014 | HP LaserJet Enterprise 500 MFP M525dn
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
I need help with my dell printer. it wont print
Hi, Malcolm.
If there are no jobs in the queue, be certain that your USB cable is snug.
If still a problem and there are jobs in the print queue, go to Printers and Faxes and delete your Dell printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, let us know if any error messages and please provide more details including your printer model.
Hope that helps.
Oct 01, 2009 | Office Equipment & Supplies
Prints gibberish
First test a different USB cable. A faulty data cable can cause the problem.
Once you are sure the cable is OK, reinstall printer software. A corrupted or wrong printer driver software is common cause for this kind of problem.
You can reinstall software using printer disk, or download from manufacturer website.
Start software setup with printer USB not connected.
Sep 10, 2009 | Office Equipment & Supplies
HP 1020 LaserJet Problem I can only print one job and then have to restart the computer before it will print again. The jobs are in the print que, they just won't print. When I restart the computer a...
Change the USB cable. The cable you are using isn't sending data BACK to the computer that tells the computer that the printer is ready, and you have to reset, Change the USB cable for a NEW one, and then your computer will talk to your printer and vice-versa.
Feb 16, 2009 | HP LaserJet 1020 Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
Not printing
Try changing the USB cable then if doesn't work uninstall printer the unplug. Install drivers first then plug in the machine.
Try this hope it works for you
Thanks J
Sep 26, 2007 | HP LaserJet P2015dn Printer
162 people viewed this question
k24674
jasbo
jasbo
