Question about Kitchen Ranges
Oven not heating properly, replaced thermosate now burner switches make a hissing sound and there is a clicking sound coming from the back. The broiler element now works but no heat in the bake element.
Maytag stove control panel model no PER4311ACW
Posted on Jul 07, 2008
American Range AR-6 Oven is not turning off
the oven control thermostat is not closing when you turn it off . it has to be replaced.be sure to turn off the gas first.
Dec 03, 2013 | American Range AR-6 36in Commercial 6...
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
When i turn on the knobs to the burners i dont hear the hissing sound and the burners do not light or anything..
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Ovens
Hi: I just installed Frigidaire gas range and have a couple questions. 1. 2 surface burners each have flame too high on only half the burner. it shoots up pretty high. How can I adjust this? 2....
Hi. There is an adjustment screw on each burner. Just make tiny adjustments until you are happy with it. Regarding the gas hiss, yes that is normal.
3 thumbs up please. Thanks, Joe
Oct 15, 2010 | Kitchen Ranges
GAS NOT COMING ON.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 14, 2010 | Bosch HGS 255 Gas Kitchen Range
Why would an electric oven stop working? I tested the element
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help. Repair and checking tips for surface burners.
Nov 16, 2009 | GE Kitchen Ranges
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Problem with oven ignition unit
It works...But I called to have the oven checked out. Thanks, tnf
Feb 19, 2009 | Kenmore Kitchen Ranges
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Kitchen Ranges Logo
252 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
