Question about Kenwood KDC-MP142 Car CD/ MP3 Player
Wiring is correct, but the cd player itself will not turn on.
    Problem Solver:
  • 17 Answers
First thing to do is check whether there is power getting to the unit. First unplug the unit and use a test light to ensure the unit is getting 12v on both accessory and constant, if the power is not coming through either of these the unit will not work. If there is no power on one of these wires proceed to check both your audio fuses both in-car and under bonnet if blown replace and check unit. If unit still not working check the fuse in the rear of the unit. If the unit still fails to turn on return it to the place of purchase and get it checked.
Kind Regards
Influential Customs
Posted on Dec 30, 2010
Driver side speaker keeps going in and out. Have any idea what this could be?
It could be the wiring going from the radio to the speaker. It would most likely be right at the speaker contact points or just behind the kenwood cd player at the wire harness. If all wiring looks snug tightly then double check for shorts. Wires chafe all the time then intermittently touch other wires or metal on the vehicle. Assuming the speaker itself is in good condition the problem should be easy to fix. Also, make sure all fuses are the correct amps and in the correct slots.
Jun 25, 2015 | 2005 Ford Taurus
Cd player INOP. Fuses check normal. all other electronics ok
this could be your CD player itself, or the power getting to it. If you have installed the player after-market, then there is a possibility that the power cord has come unplugged, or a wire splice on the wiring harness has disconnected ... check the player itself, and the wiring harness that it attaches to. There is also a small fuse on the CD player itself (usually on the back of the player near the power cord)... if this has blown out, replacing it should fix the problem. If it is plugged in, and the fuses are fine on the car's fuse box and on the CD player itself, the you might have a short in the wiring between the fuse box and the player's wiring harness. If this is the case, you can run a bypass to the CD player's power, or you can take it to a professional to have the problem diagnosed. If you are not experienced with installing car audio components, I recommend the professional assistance -- with the car in front of them, they can run more tests and tell you if it is the CD player or something else.
May 26, 2011 | 2002 Lincoln Navigator
I just hooked up an aftermarket cd player in my truck, I've double and triple checked the wiring and everything is correct yet when I shut my key off the radio doesn't turn off. What can I do?
Hello ron_bgsu,
Either the "accessory" wire is always on or the KD-G120 itself is faulty.
Use a voltmeter to check the wire you have connected to the RED wire coming from the CD player wiring harness. There should be voltage only with the key on or in the accessory position. If there's voltage on it with the key off, it's either defective or the incorrect wire. If the wire tests OK, the problem is in the receiver.
Hope this helps.
Jun 12, 2009 | JVC KD-G120 CD Player
Thumping sound
You either have a bad ground from your amp to the vehicle or a problem with the amp. Where is the amp grounded? Do not ground an amp to a seat bolt or side panel on any vehicle. The weld points on the car itself cause issue with ground. Take the ground wire directly thru the bottom panel (floor) Check befor you drill! don't hit a wire/fuel line, etc. That will give you a solid ground. Keep your ground wire length to a minimum. 18" or less, and use the same gauge wire for ground as you do for power. Hope this helps
Jun 10, 2009 | Pioneer DEH-1600 CD Player
My cd player will not work in 2005 my chrysler 300 the radio works but the cd player wont work whats wrong
Your chrysler 300 has a factory amplifier built in to the system. Seems you have connected the radios antenna turn on wire (usually solid blue) to the factory amp turn on wire. You must disconect the radios antenna turn on wire and connect the blue wire with a white stripe to the factory amp turn on wire. The problem with the blue antenna turn on wire is that when you are switching from radio to cd the unit is shutting off power on that wire(because it thinks its trying to lower a power antenna) Once the correct blue/white wire is connected the factory amp will stay on wether its am/fm or cd. Hope this helped
Jun 10, 2009 | Car Audio & Video
Ford KA Right speaker broken
Hello jump_in_the_, You need to determine if the problem is in the speaker, the wiring or the CD player. It appears that you have already eliminated the CD player, so it must be the wiring or the speaker itself. Connect a known good speaker and see if it works. If it does, then the speaker is bad and needs replacement. If it doesn't, then the wiring is faulty. In that case, run a new wire directly from the CD player plug harness. Hope this helps.
Jun 05, 2009 | Car Audio & Video
When my headlights come on my cd/dvd player screen turns blue
First of all your system is wired incorrectly. The person who wired it up is using either a power or remote signal from a light switch. That's NOT good. To correct find proper remote wire or you can use a power source that turns off when you turn ignition off and remove it from the Head light switch wires. Easy to find use a test light and check for power wire when ignition is on and No power when ignition is off. Good Luck contact if you need more help.Thanks for using FIX YA
Jan 06, 2009 | Power Acoustik PADVD340TV In-Dash...
Need wiring schematic for radio
Are you looking for the wiring diagram for the car or the cd player itself? If you have the wiring diagram for the CD player, and a test light, you can easily install with out the car wiring diagram. If you require more assistance please let me know.
Nov 28, 2008 | 2002 Buick Park Avenue
Cd player installation
read my other solution on the other one you posted. yes, the fuse is more-than-likely blown. but also you wired it completely wrong. look on my other solution on the other one you posted, it has the correct wiring diagram. there are 2 wires on the wiring diagram i posted that have the lights. one red is the int.light, and the other one is the turn signal wiring.
Aug 22, 2008 | 1990 Ford Taurus
Sony cd car stereo
Your Cd Player has a cell phone mute wire (lt blue) to connect to a car kit.
You may have inadvertently connected it to something else, or the bare wire may be making contact with something causing it to engage the ATT (MUTE).
Best of Luck.
Oct 25, 2007 | Sony CDX-CA750X CD Player
Kenwood KDC-MP142 Car CD/ MP3 Player Logo
97 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
