Hitachi 53" blue distortion
I have replaced both the red and blue ICs and the 1.8 and 3.3 resistors and I also had the whole board checked for resistance and continuaty but the blue is still distorted at the top and bottom toward the center. I tried lining up the blue manually using the remote but still limited to how much I can line-up the horizontal line. Do you have any other suggestions that I should do or look for. I appreciate all your help.
Thanks,
Gil
  • 5 more comments
  • gilcurameng Jul 07, 2008
    The model # of my tv is 53UWX10BA.
    Thanks...
    Would be possible for you to send me a diagram of the convergence circuit board in pdf format. I would really appreciate it.
    Thanks.
  • gilcurameng Jul 09, 2008
    Slinteriors,
    All the resistors checked out fine with the exception of RK54 it was reading 2.9 ohm and it looks like its burnt so I replaced it. After I put everything back together, the tv was working fine. With the tv on about 5 minutes, the picture started to wiggle out and it went blank. The red led on the power switch started to blink constantly along with DP11 and DP35 green led's on the Deflection PWB. DP23 green led and DP06 red led (Deflection PWB) stayed lit did not blink and when I turned the power off, DP23 and DP06 went dim and darker at the same time. D912 green led on the Power Supply PWB is off even with the tv power on. Any suggestions will be greatly appreciated and as always, thank you very much for all the help you have provided me.
    Gil
    It's still doing the same thing.
  • gilcurameng Jul 10, 2008
    Slinteriors,
    I disconnected the bridge between the convergence board and the deflextion board (PDKP) and the tv powers up. Also, with all the wires including all the bridge connected and the blue IC taken off the convergence board the tv powers up. Any suggestions?
    Thanks,
    Gil
    yeah, they all checked out fine with the exception of RK 54 which was reading 2.9 ohm. the diagram calls for 1.5 I replaced it with a 1.8, could that be the problem?
  • gilcurameng Jul 19, 2008
    I have changed the 1.8 resistor to 1.5 and checked the rest of the resistors that you suggested. With everything connected, when I turn the power on it powers up but has no picture. DP23 green led on the deflection board is not lit. Please help.
    Thanks
    Gil
  • 8,617 Answers
I will need the model number of your Hitachi and I can then pull up your info and see whats going on for you. Please respond to this same post.
Posted on Jul 07, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Jul 07, 2008
    Check these 6 resistors, they will have to have 1 side lifted out of circuit by unsoldering them, But if these resistors are out by 5% the convergence wont work. They cannot be checked in circuit. they have to have the one side unsolderd and lifted from circuit. They are RK42 3.3 ohm, RK46 1.8 ohm, RK50 2.7 ohm, RK54 1.5 ohm, RK58 3.3 ohm, RK62 2.2 ohm. These are all 1 watt 5% metal film resistors. One of them must be open.
  • Sonny Berry
    Sonny Berry Jul 08, 2008
    send a request to my email, and i will send you the schematic you need. my email is slinteriors@yahoo.com
  • Sonny Berry
    Sonny Berry Jul 09, 2008
    Un plug the 3 convergence yoke plugs to take the convergence circuits out of the equation and try to power up the set. If it powers up, there is still a problem in the convergence circuits. Let me know what happens after you unplug the convergence yokes.
  • Sonny Berry
    Okay, the convergence circuits are intact. Evidently it has to be a power supply problem. I would check the low voltage regulators first, then move on to the vertical and horizontal outputs next.
  • Sonny Berry
    Sonny Berry Jul 10, 2008
    if the set powers up with the blue convergence plug unplugged you have a short in the Blue convergence circuit. Did you unsolder one end of each resistor that I listed earlier and check them with one side lifted from circuit?
  • Sonny Berry
    yes it could be as 1.8 ohm is too much resistance for the circuit. It needs to be the 1.5 ohm
53uwx10ba.....seeing double/triple, colors primarily red white blue...can we fix this ourselves? and does the front of the tv come off?
Yes,but the front that not what u wanted to be open.The back of the tv that what u wanted to be open.That where the tv convergence board is,that the board require reparing.Yes,if U have all the tools and can do basic soldering works too like take out desoldering ICS take it out of a circuit board and resoldering ICS on put in onto a circuit board and also desoldering/resodering like take out small components parts and replace with new small components parts onto a circuit board?Yes?The tv convergence board must require replaces like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.Tries websites like Tvrpairworld.com,Tvrepairkits.com to buy a whole complete convegence kit belong to ur tv make and model the kit also will have a dvd disc of tutoring job too.Or tries tvs shops will cost u like $300-350 for parts and labors.
Sep 03, 2011 | Hitachi 53UWX10B 53" Rear Projection...
I have a Hitachi 53FDX20B projection TV. The Red color seems to bow. I have tried to perform MAGIC FOCUS to no avail. Additionally, I took the front panel off to manipulate the adjustable knobs. What I...
problem will be either Bad resistors ,in front of the Convergence ICs or ICs and resistors need to be replaced. ICs are big black ICs and will have part number on them STK392-110 use 120s or 150s
Mats Electronics has Parts ask for Convergence repair Kit. 1-800-628-1118
Mar 01, 2011 | Hitachi 53FDX20B 53" Rear Projection...
My hitachi keeps showing red and blue bands. when
Replace your convergence ICs they are big black ICs will have part number on them STK392-110s use 150s better ICs Mats has them 1-800-628-1118 also CK Low ohm reisitors 1.5ohms and up 3.9 ohms
May 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Looks like I have 3 different colors of the picture....red shadow and I think the other shifted color was blue...
Replace Both of your STK ICs STK 392-110s use 150s or 180s they are Big Black ICs will have part number on them. Call Mats Electronics for parts 1-800-628-1118 also replace these resistors RK42,RK46, RK50, RK54,RK58, RK60.
Dec 29, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Red line
The Convergence Circuit has failed. The Convergence ICs probably need to be replaced. There may also be a burnt resistor that would also be replaced. They should be replaced as a pair. The ICs needed are as shown. STK392-110, STK392-120, or STK392-150. If you are not comfortable trying to repair the set, call a Hitachi Professional.
I hope this helps,
Skyassoc
Jul 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color suddenly switches to 3 separate colors and is wavy
Replace STK ICS Both of them they are your convergence ICs will Have Part Number on them 2 big black ICs and there is Low ohm resistors that should be replaced also.rk42,46,48,50,52,54,60 62.
Repair Cost in Shop 325.00 and up.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence problem
did you replace the six convergence resistors with the ICs? as Hitachi recommends replacing the six resistors when the ICs are replaced as the old ICs can harm the resistors and they will need replacement.
Sep 27, 2008 | Hitachi 53FDX20B 53" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi projection tv
I would change both ICs STK392-110 and also the 3.3ohm 1 watt resistors and the 1.8 ohm 1 watt you would need 2 of each resistor. Then your convergence would be new again. You can get replacement ICs and resistors at the following link with free shipping and free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Televison & Video
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
