Question about Panasonic KX-T7453 Corded Phone
7453 Display At home - D308, 7453, works normal, shift alternates between cont ring bgm and sta ext fea new old just fine. At work, D1232, 7453, but only alternates between cont ring bgm and new old. What have I missed to make the sta ext fea show up? Thanks
  • Steph Gilgut Jul 16, 2008
    That's prolly it. Version seems to be '1', ROM is P101E 60905A.
    Thanks!
    Problem Solver:
  • 14 Answers
Without looking up details on versions, I think you may have an early D1232. Look at the plate on lower edge/front and see if there is a number in a circle. If there is no version number, the serial number will tell when the system was made.
Posted on Jul 16, 2008
I have a 97 chevy silverado c1500 ext cab 2wd automatic the truck stopped shifting. I had a tranny rebuild done and then park reverse and neutral worked but it wouldn't shift outta 1 st. Got new shift...
1st and 3rd gear only sounds like a broken sun shell he should feel bad... The only real issue on those 96 97 transmissions is the solenoid resistance values so swap ur solenoids with the one u want to put in and it will work fine if u do ur home work first.. U got to know why they wont work thats how u find cheats... But first and third sounds like a stripped or sheared shell...was reverse gone to
Dec 03, 2012 | Cars & Trucks
What does bgm off mean? One phone is not ringing on a hybrid system but the rest are. I can call out but cannot transfer, it is saying bgm off.
BackGround Music on an idle phone, if it's allowed, pressing 1 turns the BGM on and off.
Ringing comes from the ringer switch on the left side of the phone and system programming.
System programming is usually done from a display phone at extension 101 (or 11) and involves programs in the 400's for ringing (408-410 on a TA box).
You transfer a call in a couple of different ways, one is by pressing TRANSFER and dialing the extension, one is by putting the call on HOLD and calling them on the intercom to a specific line, and the 3rd is by just pressing the preprogrammed DSS button, fairly problematic in a phone that only has 12 buttons with lights.
The 7730 was first delivered with the TA series systems, but they are backward compatible with every KX-T series and forward compatible with even the latest Pana digital boxes of the TD and TDA/TDE/NCP series.
Carl
Apr 11, 2011 | Panasonic KX-T7730 Corded Phone
My BGM, back ground music used to work, now it does not. We use it only for music at our work stations. We press BGM for some music then toggle it off if necessary. It automatically shuts off if the...
Since a TD system BGM is just a single press "1" on an idle phone to turn on or off, I'm hard pressed to understand what you mean about BGM being a key. If you press "1" on a display phone and it says BGM On, and it doesn't work, go back to wherever the system cabinet is and look for the BGM port on the side of the phone system. It probably means the source is turned off or disconnected.
Carl
Aug 17, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
I'd like a (relatively) simple answering machine for d1232.
I can get you there, but you have to do some programming.
A Panasonic TD-1232 starts its life with 16 analog and 16 digital ports. On the back of your digital phone is a modular jack called an XDP If you plug in a single line device and dial 390 from the digital set, and it's programmed, you will split the extensions to whatever your number is and 100 more than your number (by default). So, if you're 110, the XDP analog port is 210.
Once you get that far, it's a (fairly) simple matter to go into programming and make 10-2 (the second port for your hardware) ring on any and all lines you choose.
I hope this is a good start, as full programming is beyond the scope of a free forum.
Carl
Apr 08, 2009 | Panasonic Lands Phones
D1232 extension programming issue
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
PS3 Scart / HD
Turn it off with the "hard" switch in the back. Then turn it back on with the switch while pressing the power button on the front for 10 secs, this should reset your display settings.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Can't display caller id info
Does CID work on ANY phone in the system? The reason I ask is because prior to issue 7, a Caller ID card had to be inserted into the trunk card. If yours is older, it may not have the card.
Carl
Aug 26, 2008 | Panasonic KX-T7453 Corded Phone
Trouble with the display
Hi Mary
Which system are you using?
If you are using panasonic kx td 1232 then just press the * key keeping the handset on hook.
If you are using a panasonic kx tda system then just press the transfer button keeping the handset onhook.
To change the date you will need to goin the program mode by pressing the Program button followed by *# 1234. then it will show on the display sys pgm no : enter 000 and press autodial or enter. Then you can change the date.
Aug 08, 2008 | Panasonic KX-T7453 Corded Phone
Change home screen display
Press the * key to switch back to date and time. Also, the SHIFT button on top will change the STA EXT FEAT.
The only way I know of changing the name is in the main phone system.
Apr 23, 2008 | Panasonic KX-T7453 Corded Phone
Expanding phone system
We have existing Ativa Model # D5772 & just purchased a 2nd model How do we connect the 2 systems?
Dec 12, 2007 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
197 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
